on cylinder 1&2 they just get warm also the exhaust just gets warm not hot like 3&4 cylinder i have gas and spark to all cylinders compression pressure on all 4 cylinders is 165 psi is this right or should all 4 cylinder get hot
on 1&2 cylinder i can touch the motor and exhaust right off cylinders just warm ever after a 30min run time does not get hot like 3&4
Edited by Rickone
try to make it more clear
Hmmmm, you would think so but if it is running strong and accelerating like the wind then I guess it's normal then. Maybe the rear cylinders are overheating like the cooling system needs flushing. Are you feeling the motor or the exhaust pipes??
  • 2 weeks later...
Yes all 4 cyl should be same (close)temp. If you have only suddenly noticed this there is a good chance the pilot jets on the offending(cold) cyls have been plugged from bad gas/varnish. Try synching the carbs first, if they won't synch properly then all 4 need be cleaned/rebuilt
Before Yammer gets here, let me be the first to say...
Seafoam, available at walmart, Auto Zone etc.
Mostly white can with red lettering, around 12 oz. About $8.00
Gary
