Have the motor out of the scooter do do a few enhancements on it and had a problem last night.
I was able to get 15 of the 16 head studs out of the block, and literally the last one I went to do would not budge with a double nut setup.
Put Red Loctite on nuts and let it cure over night, and still wasn't budging. A little more torque with a pipe wrench and it let go.
I was getting concerned.
Never used Loctite to disassemble something before.
Gary
Yep, that is a new use. Now you need HEAT to get that red death coated stuff apart Putting in stronger rods that will handle the 200 shot of nitrous ?:thumbsup2:
Actually,the nuts came off the stud without heat.
I wouldn't have to pull head studs to change rods ! !
:mo money:
Gary
