I have an extra rim and waging on my jack to come in. There is a tire shop on your side of town that will mount it. Wanna try it on my rim first? It may be another month before I get it done
I don't think I'm ready to take the plunge just yet...was the extra wheel expensive? Which tire are you going to try...the Pirelli...and will it be a "run flat"?:confused24::think:
Gonna use a non run flat..That way I can still use my TPMS
Tom, If you have the rim and tire, I can pick it up from you when we swap the oil drums, mount it and get it back to you the next week or so.
I am checking on a Yokohama envigor 195 55 16 tire If the local guy can get it for the same as internet I may take you up on that. I went and looked at a Kumho run flat today and it has alot of tread on the ground and this guy really takes the curves hard..scraped up pegs bigtime..I like the 1201 lb rating on it.
you darksiders, :shock3: ya'll still have a way to go to catch up with my two c/t's on the rear at the same time :stirthepot:
reguards
don c. :whistling:
You definately ain't right!
  • 1 year later...
Well, going to give it a try! First have to find a place that has the Michelin Alpin...then Tom is going to take me a round to get it mounted, then have it and the centramatics installed on the bike. All this will take place the first part of June.
