Bill Chambers Posted February 19, 2011 #1 Posted February 19, 2011 In a nut shell I had a new clutch put in,rode for a couple months parked for a year (due to med reasons) I am back and no resistance on clutch lever (lever pulls back to easy) and no leaks under or on bike? 99RSV
MiCarl Posted February 19, 2011 #2 Posted February 19, 2011 No resistance sounds like a problem with the hydraulics. Even a shot clutch will have resistance. BTW, 99 is a second generation.
Eck Posted February 19, 2011 #3 Posted February 19, 2011 I would" 1st check to see if the clutch reservoir is full 2nd I would very carefully see if the clutch bleed screw is loose at all where it let some air into the system.. 3rd, I would try to bleed the clutch system completely.. It may be that the rubber pluger in the clutch reservoir / master cylinder went bad and it is letting the clutch fluid by-pass it. There is no way the clutch itself can not go bad by letting the bike sit.....something else (something simple/ cheap - $$) is wrong..
Bill Chambers Posted February 19, 2011 Author #4 Posted February 19, 2011 Thanks I will bleed in the morning.
dingy Posted February 19, 2011 #5 Posted February 19, 2011 Here are a couple of pictures from the 1st gen service manual. Clutch slave cylinder is very similar to RSV's. As Eck mentioned, the piston seal shown in first picture is a potential point of failure. If this seal failed, the hydraulic fluid probably is still trapped in slave cylinder housing, which is why you saw no puddle. Gary http://i1007.photobucket.com/albums/af193/gdingy101/clutchseal.jpg http://i1007.photobucket.com/albums/af193/gdingy101/clutchslave.jpg
