In a nut shell I had a new clutch put in,rode for a couple months parked for a year (due to med reasons) I am back and no resistance on clutch lever (lever pulls back to easy) and no leaks under or on bike? 99RSV
I would"
1st check to see if the clutch reservoir is full
2nd I would very carefully see if the clutch bleed screw is loose at all where it let some air into the system..
3rd, I would try to bleed the clutch system completely..
It may be that the rubber pluger in the clutch reservoir / master cylinder went bad and it is letting the clutch fluid by-pass it.
There is no way the clutch itself can not go bad by letting the bike sit.....something else (something simple/ cheap - $$) is wrong..:thumbsup2:
Here are a couple of pictures from the 1st gen service manual. Clutch slave cylinder is very similar to RSV's.
As Eck mentioned, the piston seal shown in first picture is a potential point of failure. If this seal failed, the hydraulic fluid probably is still trapped in slave cylinder housing, which is why you saw no puddle.
Gary
http://i1007.photobucket.com/albums/af193/gdingy101/clutchseal.jpg
http://i1007.photobucket.com/albums/af193/gdingy101/clutchslave.jpg
