dingy Posted February 19, 2011 #1 Posted February 19, 2011 Where would I find the listing for the head bolts in the parts fiche? 1988 1300 MKII I have looked in the Head & crankcase sections, as well as others, but I can't seem to find them. I may need to replace a few here in a few weeks, may not need to. Just trying to find a listing for them. Anybody got a recommendation on procedure to remove them from the crankcase? Normally I use Partshark.com Gary
MiCarl Posted February 19, 2011 #2 Posted February 19, 2011 You're not finding them because they are studs and nuts. Furthermore the studs are not drawn, but indicated in the lower drawing of the crankcase fiche. #8 & #9 in the crankcase fiche: 90116-10411-00 BOLT, STUD #30 in the cylinder head fiche: 90179-10414-00 NUT
dingy Posted February 19, 2011 Author #3 Posted February 19, 2011 You're not finding them because they are studs and nuts. Furthermore the studs are not drawn, but indicated in the lower drawing of the crankcase fiche. #8 & #9 in the crankcase fiche: 90116-10411-00 BOLT, STUD #30 in the cylinder head fiche: 90179-10414-00 NUT Thanks Carl. I guess not calling them out on the drawing makes it hard to find them though. Gary
MiCarl Posted February 19, 2011 #4 Posted February 19, 2011 It makes it real hard. I missed it too. I went to the 2nd gen to search by part number and just happened to notice them there.
