GolfVenture Posted February 13, 2011 Posted February 13, 2011 If 8 fl oz for a M/C is recommended for the 1st time, then would 32 fl oz for a 20 gal tank be recommended for a truck or is that too much for a 1st time. The truck runs fine its just that it is a 1993 and thought a clean up probably be good for it.
flb_78 Posted February 13, 2011 Posted February 13, 2011 I don't have a can of Seafoam handy, but I believe it says to use 1 can for a tank of fuel in a car or truck.
Yammer Dan Posted February 13, 2011 Posted February 13, 2011 I would just run it down to about a 1/4 tank or less and put a can in it. Then run it as low as you dare.
Thom Posted February 13, 2011 Posted February 13, 2011 2 oz. per gal. but i use 4 oz. per gal. I let the tank get 1/2 full dump in 2 cans drive around town and than let it sit over nite than drive it until the tank reads E . my car don't run very good until i have filled it up after running the seafoam out . It sure helps clean the carb. and the 460 lov's a clean carb !
utadventure Posted February 13, 2011 Posted February 13, 2011 I would just run it down to about a 1/4 tank or less and put a can in it. Then run it as low as you dare. That's what my mechanic had us do. Run it 20 miles, let it sit overnight and then top off the tank. Dave
Yammer Dan Posted February 13, 2011 Posted February 13, 2011 Yeah I forgot to add the leave it sit for as long as you can with strong mixture in it. That does more good than anything I think.
Guest Posted February 13, 2011 Posted February 13, 2011 Ive been using Seafoam in the cars for years. Just dump a can in with a tank of gas and your set. Now, if you have one of those vehicles with a 40 gallon tank, well, maybe you need a few cans.....
cb1313 Posted February 13, 2011 Posted February 13, 2011 I use it my the gallon, the local farm and feed store sells it. I store 2 boats, 2 riding lawn mowers, weed eater, chains saws, 1 wave runner, 2 cars, 2 motorcycles, 1 generator and have never had a starting problem. YES... I do spend a bit in the fall but I have learned that is pays off in the spring when I want things to start. I thing I have stop doing is filling fuel tanks with enthonal gas for winter storage. Cb
mini-muffin Posted February 13, 2011 Posted February 13, 2011 I've used it in the cars for a while. Haven't used it in the truck, but it's fairly new (only a 2010) so I don't think it would be necessary yet. Yep I've also used it in the riding mower. Margaret
GolfVenture Posted February 14, 2011 Author Posted February 14, 2011 I'm down to almost half a tank, and I put 16 oz in. Thank You all for the advise.
