Well today I changed my fuel filter. Went with the F10024. Wasn't to bad took about 30 minutes. One think I noticed was how long the fuel pump ran. Before it would "click" for about 10 seconds. With the new filter it only clicked about 2 seconds. Anyhow the chicken thing. After getting the filter changed I started her up to check for leaks. While it's running I hear was sounds like a "chicken cackling" near the front of the engine. I gave her some rpms and the noise went away but came back when the rpm's came back down. I'm wonder If the noise could be the water pump?:confused24: .
Now for to the coolant. Should have time for that, then it's off to work. :depressed::depressed:
Check the immediate area around the bike....If you see tiny footprints then you have PYGMIES hiding out on the scoot.:shock3:
Boomer....who sez don't blame me cuz all of mine are accounted for.:whistling:
And now for a serious post... :Bunny:
I think I know that sound you're talking about. Does it go away after it warms up?
I think mine sounds a bit like a fan belt rubbing on a pulley but it goes away after it warms up.
Hmmmm, if you have a sound like a fan belt rubbing on a pulley then you may have an old crow lodged in there. Those buggers are worse then pygmies.
