I have on order, soon to arrive, a set of HID driving lights from Martin Fabrication. Combined with the (newly replaced) HID headlight from Canadian Custom Cruisers, this should create a light path that will sear the retinas out of Bambi!!
Will likely need to turn off my standard driving lights when these beasts fire up, but that's OK. The standard driving lights would just be illuminated bug catchers compared to the (claimed) light output of the HIDs. May need to install the stator upgrade next winter.
Martin Fab also has a really cool waterproof switch for turning on these lights. I bought two switches so I can turn on/off the HID headlight also. If the HID headlight is on when you start the bike, it often goes off and doesn't come back on.
Will post pics once they are installed. I'm sooooo ready for spring.
http://www.martinfabrication.com/Martin_Fabrication/Motorcycle_Driving_LIghts.html
Not the most user friendly website, but the owner seems to be a good guy.
RR
I'm not sure of the individual switch cost. $12 seems to stick in my head, but that could be wrong. I will likely have an itemized invoice once they arrive. I will let you know.
RR
