2nd Blessing Posted February 4, 2011 Share #1 Posted February 4, 2011 I am looking to add some light to the back end of my bike as it is not very bright at night with stock lighting. I am wanting to change the signal lights to L.E.D. running lights with the signal being priority when needed and possibly the tail light itself. I already have a L.E.D brake/running light bar to add just under the trunk but want more and wondering where I can find these in a simple aftermarket application or if there isn't one then how. I have some time as it will be a couple of months before our winter is done. Link to comment Share on other sites More sharing options...
Leadwolf56 Posted February 4, 2011 Share #2 Posted February 4, 2011 Check here www.customdynamics.com I just got the 100 LED tail light and they have the turn signals etc. in LED plus a lot more. Link to comment Share on other sites More sharing options...
Jactana Posted February 4, 2011 Share #3 Posted February 4, 2011 +1 on the Custom Dynamics taillight, and it's "plug and play"! Link to comment Share on other sites More sharing options...
jfoster Posted February 4, 2011 Share #4 Posted February 4, 2011 I added an additional brake light by mounting a whelen TIR3 red led strobe which can be programmed to burn steady when activated to the inspection sticker plate from jp cycles. Perfect fit and bout twice as bright as my custom dynamic's 100 led taillamp. Total cost for the Whelen TIR3 n bracket $55, not including shipping. U can get LIN 6 for $20 more which is insanely bright. VLSUSA.com Link to comment Share on other sites More sharing options...
hig4s Posted February 4, 2011 Share #5 Posted February 4, 2011 I added the tail light from Custom Dynamics and the quad light license plate frame, with the LEDs on the top and bottom brake/tail and the ones on the sides extra turn signals. Link to comment Share on other sites More sharing options...
Sandbagger Posted February 4, 2011 Share #6 Posted February 4, 2011 This is the post of the same question I asked a couple weeks ago. Got great answers and questions. There is a guy on this post named V7Goose. You might look up pictures of is bike. His bike looks to be wired about perfectly for visability in my opinion but his solution is a lot less money than most. Take care, Bob Link to comment Share on other sites More sharing options...
zooer Posted February 5, 2011 Share #7 Posted February 5, 2011 I put on a diamond R rear light and it is the brightest one I've seen on the rear. Trust me, they'll see you in the daylight and dark. Link to comment Share on other sites More sharing options...
Seaking Posted February 5, 2011 Share #8 Posted February 5, 2011 I have the custom dynamics brake light on mine, one of THE brightest out there on the road.. plug and play.. I also have the DiamondR light bar under the trunk.. and an LED strip light wedged under the passenger back rest and trunk lid. I also have the custom dynamics LED signal lights which are painfully bright as well. I also have the red side marker lights in LED, which are quite visible from behind as they protrude out from their base.. so this gives the bike a wider look in the dark. I also have the front marker lights set up as LED lights as well. I have the LED strip under the backrest and the DiamondR light bar only set on as brake light, not running. The bike's brake light running light is brighter than stock.. I set the lights like this so that when I press on the brakes, and the lights come on, there is NO mistaking that I have my brakes lights ON.. the bike goes from nicely lit running light to "IN YOUR FACE MY BRAKES ARE ON" lights.. I tend to always double tap my brakes before I know I'm going to be braking to a stop to alert anyone behind me.. I don't seem to be tail gated as often as before I got this set up. The way I have this bike lit up, anyone hitting me from behind saying "sorry I didn't see you" will deserve the beating he'll get, if I'm able to get up off the ground that is.. Anything you can do to make yourself more visible can only help.. Link to comment Share on other sites More sharing options...
SMSgt Posted February 5, 2011 Share #9 Posted February 5, 2011 I put on a diamond R rear light and it is the brightest one I've seen on the rear. Trust me, they'll see you in the daylight and dark. I have a Diamond R on my as well. It's an easy install and works as a running light and a brake light. Link to comment Share on other sites More sharing options...
Sleeperhawk Posted February 5, 2011 Share #10 Posted February 5, 2011 Here is a thread to the lights I put on with the part numbers: http://www.venturerider.org/forum/showthread.php?p=251764#poststop So far all have said I am very well lit up. Link to comment Share on other sites More sharing options...
Squeeze Posted February 5, 2011 Share #11 Posted February 5, 2011 Well, i think we think different .... lighting up the rear ?? that's my Take on the Issue ... [ame=http://www.youtube.com/watch?v=3dE4qQuKmK4]YouTube - Yamaha Vmax Burnout beim Teufelsmoor Treff 2009 V MAX 1200 300er Reifen[/ame] Link to comment Share on other sites More sharing options...
Crash Posted February 5, 2011 Share #12 Posted February 5, 2011 I don't own a Bike right now but there are pictures of my 05 Midnite Venture in my profile. I definitely would be seen in daylight and dark!! Link to comment Share on other sites More sharing options...
2nd Blessing Posted February 6, 2011 Author Share #13 Posted February 6, 2011 thanks for all the help. don't want to over load the back as I like a clean simple look but you all have been great help for the next step in getting the back brighter. next will be the front but need to work slowly on this simply due to money, not desire or time. Wally:snow2: Link to comment Share on other sites More sharing options...
aharbi Posted February 7, 2011 Share #14 Posted February 7, 2011 This is what I did. Note discussion was only a month or two ago. http://www.venturerider.org/forum/showthread.php?p=531838#post531838 Link to comment Share on other sites More sharing options...
DanC Posted February 10, 2011 Share #15 Posted February 10, 2011 (edited) I am looking to add some light to the back end of my bike as it is not very bright at night with stock lighting. I am wanting to change the signal lights to L.E.D. running lights with the signal being priority when needed and possibly the tail light itself. I already have a L.E.D brake/running light bar to add just under the trunk but want more and wondering where I can find these in a simple aftermarket application or if there isn't one then how. I have some time as it will be a couple of months before our winter is done. See my post on "Inexpensive Rear Lighting" by DanC:080402gudl_prv: Edited February 10, 2011 by DanC spelling error Link to comment Share on other sites More sharing options...
latchkey Posted February 10, 2011 Share #16 Posted February 10, 2011 check out my pics of the leds i put on saddle bags and rear. in my profile, $7.00 for each at autozone Link to comment Share on other sites More sharing options...
BigDawg Posted February 11, 2011 Share #17 Posted February 11, 2011 I have the custom dynamics brake light on mine, one of THE brightest out there on the road.. plug and play.. I also have the DiamondR light bar under the trunk.. and an LED strip light wedged under the passenger back rest and trunk lid. I also have the custom dynamics LED signal lights which are painfully bright as well. I also have the red side marker lights in LED, which are quite visible from behind as they protrude out from their base.. so this gives the bike a wider look in the dark. I also have the front marker lights set up as LED lights as well. I have the LED strip under the backrest and the DiamondR light bar only set on as brake light, not running. The bike's brake light running light is brighter than stock.. I set the lights like this so that when I press on the brakes, and the lights come on, there is NO mistaking that I have my brakes lights ON.. the bike goes from nicely lit running light to "IN YOUR FACE MY BRAKES ARE ON" lights.. I tend to always double tap my brakes before I know I'm going to be braking to a stop to alert anyone behind me.. I don't seem to be tail gated as often as before I got this set up. The way I have this bike lit up, anyone hitting me from behind saying "sorry I didn't see you" will deserve the beating he'll get, if I'm able to get up off the ground that is.. Anything you can do to make yourself more visible can only help.. Seaking, any chance we could see some night time pics of your setup? Rear lighting is still on my list of upgrades, so I'm still investigating what others on here have done. Picture is worth 1000 words, right? thanks! Brian Link to comment Share on other sites More sharing options...
Guest gerrycormier Posted February 13, 2011 Share #18 Posted February 13, 2011 Check out Princess Auto Sale on rear LED lights. Gerry:lightbulb: Link to comment Share on other sites More sharing options...
