warriorhoneybee Posted February 3, 2011 Posted February 3, 2011 whats the big dirrerance in running the factory type bias tire vs going with a radial?? i noticed the dun e-3 offers it in both but dont know about the avon.
MidlifeVenture Posted February 3, 2011 Posted February 3, 2011 http://www.venturerider.org/forum/showthread.php?t=42907&highlight=bias+radial http://www.venturerider.org/forum/showthread.php?t=40400 Here is a couple in the archives
Guest scarylarry Posted February 3, 2011 Posted February 3, 2011 I read the links and I too read somewhere that radials tire are not to be use, but for the life of I can't find it... I know Avons sells them, if the dealer give me a I will be installing them
Kirby Posted February 3, 2011 Posted February 3, 2011 whats the big dirrerance in running the factory type bias tire vs going with a radial?? i noticed the dun e-3 offers it in both but dont know about the avon. I haven't seen a radial that will fit the stock RSV rim for the rear! 17 inch I believe. But if you have, please post a link!! I'd be interested the next time I have to change out!!!
Brake Pad Posted February 3, 2011 Posted February 3, 2011 I haven't seen a radial that will fit the stock RSV rim for the rear! 17 inch I believe. But if you have, please post a link!! I'd be interested the next time I have to change out!!! I run the 180 Radial on my back and the stock 150 on the front. I find less chance of chucking tires, now this is on the Metlzers. I ran two 170's and chunked both, I moved up to a radial 180, and I'm happy with it. plus a tad bit more rubber on the ground while pulling a trailer:biker:
Guest scarylarry Posted February 3, 2011 Posted February 3, 2011 Jake wilson has them also.. This is for the front tire and they do have the rear tire as well. Little pricey though.. http://www.jpcycles.com/product/210-200
warriorhoneybee Posted February 3, 2011 Author Posted February 3, 2011 thanks for the info on the tires and price.
Kirby Posted February 3, 2011 Posted February 3, 2011 Ok, so nobody caught it !!! The rear of the RSV is 15" NOT 17" rims. I went into the other room and it dawned on me what I said . I ran back in here to see how many caught it but none did. It is 15 inchers!!!
hig4s Posted February 3, 2011 Posted February 3, 2011 Ok, so nobody caught it !!! The rear of the RSV is 15" NOT 17" rims. I went into the other room and it dawned on me what I said . I ran back in here to see how many caught it but none did. It is 15 inchers!!! I was sitting here thinking, aren't the back rims smaller than the front, but I hadn't gotten around to checking yet.
Guest scarylarry Posted February 3, 2011 Posted February 3, 2011 Ok, so nobody caught it !!! The rear of the RSV is 15" NOT 17" rims. I went into the other room and it dawned on me what I said . I ran back in here to see how many caught it but none did. It is 15 inchers!!! I caught it but before I said to much wanted to make sure they even make a radial tire for the RSV.. That is why I copy the link the 15 and not the 17.......:rotf: But still not for sure you can run them ok on a RSV....I'll call my stealer and maybe he will answer it with out a fee
Kirby Posted February 3, 2011 Posted February 3, 2011 I ran an Avon Cobra radial on the front during the time I was trying to get the CT to work since the CT was a radial also. Couldn't ever get the wobble out so after 1500 miles I ditched the rear CT and tried a Continental bias with the front radial. Result: it road good but the Conti didn't last but about 6,000 miles so I went with the E3 on the rear. I got about 15,000 miles before changing it out because of a long trip I was planning to go on. The Cobra got a cut in it at around 20,000 miles so I replaced it with a E3 bias to match the new rear bias E3. I wish I could get a Cobra in a radial for the rear . I'd buy a set front and rear in a heartbeat.
Sleeperhawk Posted February 3, 2011 Posted February 3, 2011 Avon does not make a tire in the RSV size, at least according to their website. Also, the load rating for the radial in a tire close to the same size was not even close to the non-radial venture tire. Dunlop E3 non-radial has a higher load rating too than the radials. For me, I will take the higher load rating any day.
Guest scarylarry Posted February 3, 2011 Posted February 3, 2011 Avon does not make a tire in the RSV size, at least according to their website. Also, the load rating for the radial in a tire close to the same size was not even close to the non-radial venture tire. Dunlop E3 non-radial has a higher load rating too than the radials. For me, I will take the higher load rating any day. Your right they don't show it on their website but JW and others sell them, also you are right on the load rating too. Why they don't have them on their website is beyond me... I have been happy with the E3's but they tend to be alittle noisey so this round I will try the Avon's hey if they don't work I have the E3's to fall back on...
Kirby Posted February 4, 2011 Posted February 4, 2011 I agree with all about the load rating of the E3. I hadn't checked the load rating of the radial as compared to the E3 bias ply. Good point!!
hig4s Posted February 4, 2011 Posted February 4, 2011 Avon does not make a tire in the RSV size, at least according to their website. Also, the load rating for the radial in a tire close to the same size was not even close to the non-radial venture tire. Dunlop E3 non-radial has a higher load rating too than the radials. For me, I will take the higher load rating any day. You mean Avon doesn't list a radial in the Royal Star size?
Sleeperhawk Posted February 5, 2011 Posted February 5, 2011 (edited) You mean Avon doesn't list a radial in the Royal Star size? Haven't found any yet, unless a V means Radial. This is the rear tire where the V is 74 (827lb per load) and the H is 80 (992 lb per load). Since I am not riding faster than 130 mph, I will stick with the H (belted). Edited February 5, 2011 by Sleeperhawk
Guest scarylarry Posted February 5, 2011 Posted February 5, 2011 Haven't found any yet, unless a V means Radial. This is the rear tire where the V is 74 (827lb per load) and the H is 80 (992 lb per load). Since I am not riding faster than 130 mph, I will stick with the H (belted). Doesn't the R mean radial here? Avon AV71 Cobra 150/80R-16 Front Tire
Kirby Posted February 5, 2011 Posted February 5, 2011 Doesn't the R mean radial here? Avon AV71 Cobra 150/80R-16 Front Tire Yep! R stands for radial. V and H are for speed rating and 74 and 80 are for load rating.
Sleeperhawk Posted February 5, 2011 Posted February 5, 2011 Here is a link to Avon's site, do not see any R, only V and H http://www.avon-tyres.co.uk/motorcycle/venom
jfoster Posted February 5, 2011 Posted February 5, 2011 whats the big dirrerance in running the factory type bias tire vs going with a radial?? i noticed the dun e-3 offers it in both but dont know about the avon. Radials have a smoother ride.
Kirby Posted February 5, 2011 Posted February 5, 2011 Here is a link to Avon's site, do not see any R, only V and H http://www.avon-tyres.co.uk/motorcycle/venom Avon AV71 Cobra 150/80R-16 Front Tire This is the "R" he was talking about and yes the Avon link shows this in the tire sizes. If it doesn't have an R in the size it isn't radial. Look under Cobra for the tire mentioned.
hig4s Posted February 5, 2011 Posted February 5, 2011 Here is a link to Avon's site, do not see any R, only V and H http://www.avon-tyres.co.uk/motorcycle/venom that is the Avon Venom page,, Venoms are bias ply Cobras are radial. http://www.avon-tyres.co.uk/motorcycle/cobra
Guest scarylarry Posted February 5, 2011 Posted February 5, 2011 that is the Avon Venom page,, Venoms are bias ply Cobras are radial. http://www.avon-tyres.co.uk/motorcycle/cobra Ok to clear this up some, they make a front radial but not a rear in the 150/80-15...
