peterbooth Posted January 20, 2011 Posted January 20, 2011 Is it possible to remove the rear wheel on a 2nd Gen venture with a side car still attached? If so, what is the procedure?
SteveW Posted January 20, 2011 Posted January 20, 2011 Its easy with a sidercar attached. I have removed my rear wheel and adder a CT when I had mine. I used a floor jack up under the rear shock and let the bike tip forward and to the right side the front wheel and sidecar wheel a great pivot stop for raising the bike. You can also use the jack under the rear bottom frame mount depending how you hack is attached.
