Let's have some fun this weekend.:thumbsup2:
Cus as soon as it's done, it's under the knife to get my herniated disc fixed on Monday morning.:banana:
Can't eat or drink after midnite on Sunday:no-no-no:,
so look out between now and then.:banana::beersign:
Later, Scooter Bob
  • Replies 163
  • Created
  • Last Reply
Top Posters In This Topic
Depending on if I get everything done and loaded tonight, I would like to leave here right after work, about 5:30, on Friday night. That will get me there while it is still light out.
So I was gonna tell you that Fox Lake is farther West and here it stays light till about 9, so you wouldn't have to leave till almost 7.:stickpoke:
But then I read this...
I have a huge tent that sleeps 8.
You probably need the extra hour to set up camp.:scratchchin:
Hope to see you Friday, Scooter Bob
Doggoneit.... my TCI probably won't arrive back here by Saturday, which means the siccle won't be operational til Monday. I'm still maybe with tendency toward unlikely.
I don't need much light for setting up camp.
I do some of my best work in the dark.....
Once I set up my queen size bed in there it won't sleep 8 no mo.:confused24:
You could always just drive down here after dark,:scratchchin:
I heard there might be a 1st gen sittin' around.:confused24:
:sign just kidding: Jeff
Well, as I was checking out the shifter cam, I noticed the tab over one of the pins was bent badly, and when I tried to bend it back, it fell off. I also couldn't rotate it enough to check all the pins, and I didn't have time to remove the clutch basket to see the other pins. So I guess I will not be able to make it since I won't have a new part in time. I will keep it in mind for next time.
-Andrew
Trailer and bike are loaded for the trip. Just need to stop for gas.
It looks like there will be a window in the rain for me to sneak up there on Friday night after work. I should be hitting the road around 6-6:30. With all of the construction going on it is a bear escaping Milwaukee on a Friday. It will take at least an hour to hour and a half to break free. Then another 1+ hours to get there.
The only kink still in this plan is if I do not like the way the loaded trailer is handling. If it is still wagging with the load and better tongue weight, I'll shift to plan 2 and come up Saturday morning without the trailer.
BOB
You need to get a hold of Freebird quick to get his contact info for the weatherman. I hope it is not to late to get that horrorcast for the weekend fixed.
Hey Freebird, thanks for contact!
Mid 60s and mostly cloudy, not bad for wrenchin!
Later, Scooter Bob
Well I sure hope the weather is better tomorrow morning.
Even though it does not show on radar, there is heavy fog and rain right now.
I chickened out.
I never did like rain and I have never pulled a trailer.
Add in some fog and it overwhelmed my sense of safety.
I am hoping for better weather in the morning.
Ok so call me a fair weather rider..........
The wrenchin' has begun!
Jeff's bike has had the carbs synched and the front pads greased up.
http://tapatalk.com/mu/a6b5022a-d9c9-6756.jpg
Later, Scooter Bob
Later, Scooter Bob
weeeeelll?? with that grease on the brake pads....ya better stand behind your work?? don't wanna stand in front of it:rotf:
:whistling:mike
Bob,please remove the voodoo curse on my back...:mad:
OH NO,:no-no-no:
Do I need to book a two for special at the surgeon Monday?:confused24:
Oh YA, these trips to Fondy and Oshkosh on the bike to get this surgery set up has got my back feelin' a little better.
That 3+hour ride down here should fix you up good.:thumbsup2:
Hey Gang,I'll be leaving in an hour or so...
Hurry up Dan...Half the guys here right now are named JEFF.
Jeff (J Berg) is in the middle of clutch upgrade now. Neck bearing tightened, stock HD mufflers installed, bags back on. almost ready to go.
If I don't show by noon,send out a search party...:yikes:
first gen guys get lost real easy ya know:rotf::080402gudl_prv::cool10::whistling:
made it home in 1hour with a stop for gas and the internet said it would take 1hr 20 min,not bad htanks to everyone for all the help.runs much better after that carbsync.have a good nite guys and galls.have a couple porkchops in a can for me while i'm at work.
:bawling: :bawling: :bawling: :bawling: :bawling: :bawling: :bawling:
I wanted to go too, but had to work. Bah Humbug!!! :bang head:
Hope everyone has a good time and Scooter, easy on the back buddy don't over do it. :thumbsup2: :sign woo hoo: :beer:
Bryan
Karen and Stacey put on a wonderful lunch spread...
http://tapatalk.com/mu/a6b54121-cc49-0396.jpg
http://tapatalk.com/mu/a6b54121-cc55-cee3.jpg
Later, Scooter Bob
Edited by Scooter Bob
the rig that he drove to don's maint day was suuuure purdy:cool10:!! what's that old relic that he's on in this picture???:confused24: and who went out and found him??:detective::whistling:
had to work today,, i hope you all had a good time. mike
Ah, the party's over.
IH Truck guy was the last to leave:stickpoke:, imagine that Don.:scratchchin:
I think a good time was had by all.:confused24:
The Roster...
Jeff #1 (J Berg) and Stacey, Carb sync, grease front brake pads,change pipes, tighten neck bearings,clutch upgrade.
Jeff #2 (Flyin Fool) grease rear drive hub pins, new air horn.
Jeff #3 (Jeff2053) carb sync, check brake pads, change rear gear libe,tighten neck bearings.
Jeff #4 (RedRider) new battery.
Rick (Rick Haywood) and Shirley, carb sync, fix air horn, tighten neck bearings
Bill (Wkoepke) and Heidi, just visitin'
Steve (EagleEye), just visitin'
Dan (IH Truck Guy), clutch upgrade, cleaned oil from floor.
All in all, a good days work, and a lot of the worlds problems solved as well.:clap2:
Thanks for coming everyone, Scooter Bob and Karen
