I did like swifty suggests. And it's easy, I just redid the wiring. BUT I have mine on a switch. "Off" for back roads and ON for hiway... because when doing 70mph on the hiway and bambi jumps out. The anti-dive is a good thing. Yes, I have Progressive spring too.
I reworked wiring on mine so valves only work with front brakes. Bike doesn't dive much at all with rear brake only, plus I have progressives.
When I am in traffic or setting at light, I can use rear brake and valves are not engaged.
Was not real easy, I had to open up wiring harness sheathing and install a diode to accomplish.
Gary
