RIB III Posted December 3, 2010 #1 Posted December 3, 2010 My truck clutch is going out its going to be about 25 to 27 degrees out in the morning found parcka pants to wear from when I was in the Air Force in the 80's, bright carolina blue mittins from I don't know where and my leather jacket. Lets see what happens.
sarges46 Posted December 3, 2010 #2 Posted December 3, 2010 At least its not -2 F or less like it is here! And no snow either! Dress warm and watch for ice!
RIB III Posted December 3, 2010 Author #3 Posted December 3, 2010 Both feet on the ground if required.
Yammer Dan Posted December 3, 2010 #4 Posted December 3, 2010 You come and put the clutch in my Saab and I'll put the one in your truck.....
MidlifeVenture Posted December 3, 2010 #6 Posted December 3, 2010 If it has a hydraulic clutch bleed the master and slave you maybe surprised
Wolf Posted December 3, 2010 #7 Posted December 3, 2010 You come and put the clutch in my Saab and I'll put the one in your truck..... Now thats a bad deal!
Wolf Posted December 3, 2010 #8 Posted December 3, 2010 If it has a hydraulic clutch bleed the master and slave you maybe surprised Slave and master cannot cause a slip.
RIB III Posted December 3, 2010 Author #9 Posted December 3, 2010 its the slave leaking and looseing fluid. Its a 1996 F-150 and you have to pull the trany out to get to it and I don't have a garage
Yammer Dan Posted December 3, 2010 #10 Posted December 3, 2010 Now thats a bad deal! Thought maybe he was Saab Mechanic?? I could fight my way thru a ford clutch. Did you get it RIB III??
RIB III Posted December 3, 2010 Author #11 Posted December 3, 2010 I'am not much of a mechanic at all but I did get that it was alot harder to replace a clutch on a SAAB!!
Yammer Dan Posted December 3, 2010 #12 Posted December 3, 2010 Saab is a b***** Ford 2 wheel rear wheel drive? Just take your time and watch things. Thats a easy one.
RIB III Posted December 3, 2010 Author #13 Posted December 3, 2010 I refer back to the title of the thread Brrrrrr!!!!
Yammer Dan Posted December 3, 2010 #14 Posted December 3, 2010 Good Luck with it. Maybe you can wait for some sunshine!!
