Yes you can. No problem at all. Most people would recommend that the car not be running though.
:sign yeah that:
I make a small set of jumpers for the bikes. Just use one of those 6 or 9 ft extenison cords you can get for a couple bucks at Dollar Stores cut off ends and put electrical clips on them. I just feel better not throwing all that juice to a bike system. I may not be right in this but I don't think that small cord would carry enough to hurt system.
12 volts is 12 volts and that is all. You can get it anyway you want. Get a bunch of D cell batteries it you want. Amps are something different and Freebird was right with don't run the engine.
:farmer:
:farmer:
Also:
It is best to hook up the ground cable to the bike itself...Not the battery...
I thought the heavier the cables the more amps they carried.
Dead on Y D, but you don't want the high charge rate of the car alternator. That is why I just use the car battery without the engine running.
:farmer:
