thanks ..what wires did you use from the unit ...i dont want to tear into it and cut wrong wires to run back to my switched fuse panel
First off, did you get the switch that comes with the later models? If so, then all you have to do is replace the switch with the relay. Get your power to activate the relay from something that turns on with the ignition switch. I used the power line going to my Mic Mutes.
