I am looking to replace my HJC and Scorpio open faced helmets, but I am having difficulty finding helmets that can be fitted with the Yamaha standard open-faced head-set and mike. I have a Scorpio half-helmet, and used Velcro to secure the mike. It works OK, but is not ideal. The HJC is getting old (6 years), and works well, but the new ones I have found in the dealers will not readily accept the mike.
Anybody using a recent open face helmet with the audio gear that they are really happy with?
The wife and I have Gmax they come with speaker pockets and work great with a standard headset, only drawback is they are only DOT certified.
  Bobby G said:
This is what I've found to be the best ones available for half helmets, and is what I use. I tried the cheaper over-the-ears headphone type, and they hurt after about 20 minutes.
http://wingstuff.com/pgroup_detail/3145_Slide_In_Shorty_Half_Helmet_J_M_Helmet_Headset
Here's the over-the-ear headphones I was talking about. Cheaper, but more painful!
http://wingstuff.com/pgroup_detail/26740_IMC_Gold_Wing_Helmetless_OR_Half_Helmet
I just bought a pair of HJC HC-31's that match the VR's paint almost exactly (white). The stock headsets mated up very easily. The only hard part was tucking the excess wire to the right side earpieces. I think I gave about $80/each.
Scala makes headsets that use very thin speakers just a little larger than a quarter. I use it on all of my helmets. the speaker has velcro on the back and simply sticks to the lining in the helmet. just choose a spot were you won't notice it.The pic below is my half helmet with one mounted in it. the sound is by the way is excelent.
Thanks for the responses.
I have the Yamaha head-set, and while not thrilled with them, I do not want to replace them.
The issue I have is finding an open faced (not half) helmet that I can attach the microphone to.
Does Scala make a headset that will plug into the intercom jacks on a Venture? All I saw was bluetooth sets.
You may want to check out the Nolen N-43 as well. These can be either 3/4 or, if you wish, full face (by adding the chin bar). We got ours from J&M with the headsets installed and are VERY pleased with them. Seems to me that they have more "peripheral vision" than most other helmets I've tried (though in all fairness, I'm used to full face types which have more restrictive vision than 3/4's typically do.) Anyway, the 43's are very light weight and quite comfortable.
Good luck with whatever you go with!
I just got a pair of HJC FS-3 helmets from newenough.com for about $150 total shipped to my door. I unsnapped and pulled the entire inside liner out. The styrofoam ear section was easily removed with one screw. I took a razor and cut out the stryrofoam to accomodate my speakers. Put everything back together and the helmet functions perfectly but the speakers are in there and NO EAR PAIN.
http://i1110.photobucket.com/albums/h444/vegastruckee/IMG_6951.jpg
http://i1110.photobucket.com/albums/h444/vegastruckee/IMG_6952.jpg
http://i1110.photobucket.com/albums/h444/vegastruckee/IMG_6953.jpg
We use Gmax and Fulmer 3/4 open face helmets and J&M headsets (same ones Yamaha sells). No problem mounting the headset to either of these. I really like the Fulmer and would buy another when the time comes.
  • 1 year later...
Ben,
I just picked up my half helmet boom.
I noticed from your pix that you have the speaker directly on the half helmet. So using the supplied ear curtains is not really essential and the sound quality is still ok at riding speeds?
I'm not to0 crazy about using the ear curtains
+1 on the ear curtian thing. Part of the reason I wear my shorty is I want some air circulation around my neck etc. I have though about taking a pair of ear buds (like for MP3 player) and soldering them in instead of the speakers, then just mount the mic.
As far as our other helmets go the wife and I both have Bell Mag 8. The J&M headsets mounted up in about 30 min in each of them and work fine. My half is a Scorpion EX100 I like that it has a stow away shield if it starts to rain.
  djh3;684906I have though about taking a pair of ear buds (like for MP3 player) and soldering them in instead of the speakers said:
Oh yeah, I could plug in ear buds too if I don't like the sound. The plus point on the Scala is the speakers plug into the boom mic so no soldering involved.
