CrazyHorse Posted November 7, 2007 #1 Posted November 7, 2007 Has anyone fixed the plastic pins for the side panel the push pins things that go into the rubber grommet and how did you do it?
Rocket Posted November 7, 2007 #2 Posted November 7, 2007 Has anyone fixed the plastic pins for the side panel the push pins things that go into the rubber grommet and how did you do it? Check with Black Owl, for some ball studs to replace them with. It is an easy way to replace any broken pins. I used nylon lock nuts on my ball studs, when I installed them.
Wizard765 Posted November 7, 2007 #3 Posted November 7, 2007 I think Plastex will do the job. I've used it to fix tabs and actually replaced tabs with it. Not the peice you are talking about but similar. Check out their video. http://plastex.home.att.net/
hipshot Posted November 7, 2007 #4 Posted November 7, 2007 Has anyone fixed the plastic pins for the side panel the push pins things that go into the rubber grommet and how did you do it? jim, if you were lucky enough to have the broken off post, stay in the rubber grommets, then you can simply glue them back in place. if ,not, then you will have to fabricate some new posts. in order to do that, you really have to WANT to. we're talking modeling clay, and "homemade glue", and lots of time. just jt
IH Truck Guy Posted November 7, 2007 #5 Posted November 7, 2007 Check with WKBOARD {Alan} from Chicago.He told me he made a mold and used Plastex..with great results...
86er Posted November 7, 2007 #6 Posted November 7, 2007 Blackowl is your best bet for the ball stud info! Check out this thread. I ordered some from hom to have on hand if I need them. Now if I can just remember where I put them! And for other plastic repair I've used Devcon Plastic Welder (2 part epoxy) and fiberglass cloth with great success. Easy to replace/rebuild tabs and reinforce cracks.
Marcarl Posted November 7, 2007 #7 Posted November 7, 2007 There, now that you got all the answers, get to work and then post some pictures!!!!!!!!!
Yammer Dan Posted November 7, 2007 #8 Posted November 7, 2007 The Ball Studs are the way to go. Black Owl did you order some more of those??
Venturous Randy Posted November 7, 2007 #9 Posted November 7, 2007 The best thing to do is go to Wally World and buy some Industrial Strength Velcro. Take the rubber grommet off and cut and fit a piece of Velcro on the flat area. Then put a piece of matching Velcro on the panel. I gar-ran-tee you it work as good as the pins and grommets ever did!!! RandyA
CrazyHorse Posted November 7, 2007 Author #10 Posted November 7, 2007 Wow lot of good ideas. After my crash my big fairing piece is in shambles luckly I had a replacement of the same color I previously bought on ebay. Now I have a big practice piece for plastic welding and trying different ideas of plastic fixing. I previously fixed my chin piece just with ABS plumbing glue. Now I get to fix it again and you know what it didn't break in the same place as before. The pins are still attached to the big fairing piece. I'm gonna try to repair as much as the plastic I can basically the whole right side. I gonna have to buy the inside plastic fairing piece too damaged and maybe the headlight/dash frame. I'm gonna try a local hardware store for those little ball things this store has every little wierd bolt/nut you could want many in stainless or chrome for bikes also metric/english I love that place.
Tupperj Posted November 14, 2007 #11 Posted November 14, 2007 Guys, sorry to come in late on this, been out breaking the Mark I in. I'm a firm believer in Stainless Steel Socket Head Cap Screws. As I was looking at some broken pins, it occured to me that a 6mm SHCS would fit, and it does, very well. You can get them in several lengths (I buy in bulk from Grainger) and use a couple of nuts to hold them in place. If they aren't QUITE tight enough for your liking, put some heat shrink tubing over the ends. I know, I know, this is useless without pics. Will try to get some in the near future. Too busy freezing in West Virginia and loving the Venture! Paul
Thom Posted November 14, 2007 #12 Posted November 14, 2007 i just heard a new trick to make our fairing stronger , use spray foam inside of weak corners makes it a lot stronger , use a drill with a long drill bit to carve the foam .
