rlyons
i ordered the greenboat led driving lights....and they don't fit...they are too small for my housings....i measured them and they are 4 1/4 in. diameter......the stock ones are 4 1/2....so how did you get them to fit.......they say par 36........
no
i ordered from this site and from the original link....as you've posted... and they are 12v-15v par36.......led......now, i have the housings for the strat ( i think that's the model) that you mount on our ventures.....but those are par 36 housings......the problem is that these led's are 4 1/4...not 4 1/2.....so i don't see how ya'll made 'em fit...or , you know, why mine are 4 1/4.......
no
Cant answer that. Thats the same part # I used and they fit perfectly. What is yours doing? Is it rattling around in the light housing?
yeh....i liked 'em to......and some people ordered 'em and say they fit right in.....but no way are they going to fit......curious as to what ruffy's and rlyon's measured....
ruffy
yeh....they will fit up against the rubber gasket...but no way will the chrome cover hold them tight...and also hold my visor....they are just not the right diameter
I would call Greenboat stuff and talk to Angie to see if there is any difference. Ill pull mine off maybe tomorrow and measure it across to see the size.
Depending on what housings you have there is a difference in diameter on passing lights. I had a friend order after market lights for a Venture and the sealed beams would not fit. Turns out the light housings were after market for a Road Star.
:farmer:
mine are yamaha....they're for the strat..but, like others on here , i've put them on my venture.....every par 36 bulb i've ever ordered has fit just fine........these do not...
I pulled my led off and matched it up with the stock bulb and it was just slightly smaller. Maybe 1/8" off but it fits snug, just like stock.
installed my led's today, fit just fine. wow what light, works just fine with the h.i.d. headlight. was able to do some dark driving time with them. but there is some static noise. will deal with that after the "bend ride".
reguards
don c. :dancefool:
ok.... mystery solved
the stratoliner lenses are 4 3/4 inches.....so the light housing ring inside diameter is 4 3/4 ......the led's ARE 4 1/2, not 4 1/4.........so.....all i know to try is some peel and stick insulation to try and snug the light up......
Hmmmm, sounds like a good beating is in order........:buttkick::starz:
:rasberry:
I think you'd be better off just getting rid of those lamps and going with something else.
You are welcome to PM me for my address :stickpoke::witch_brew:
nope....gonna use 'em ....already have one mounted by using closed cell stick on roll insulation around the light....
Well you are just no fun. :rasberry:
Really though, based on your last post, I had assumed that you had a plan or had it figured out and done.
Glad you got it to work :happy65:
The passing light hoursing and bar for a strat are not the same as the passing lamp housing for the venture. But I do like the passing light for the strat.
sleeperhawk..
i bet it seems some of my posts are contradictory.....the par 36 lights i tried were always for the venture housings.....when i switched to the strat...i "assumed" they were par 36 size....i just changed the bulbs........so when i got these leds...i was just thinking par 36....didn't fit...saw they were smaller than the strats lights....so, just assumed they were 4 1/4.............anyway, i found a solution..........and you can't tell, and it's a very snug fit....
Promise not to leave you honey at a gas station during the coming year.
george,
you gotta stop bringing this up:crackup::crackup:
