GolfVenture Posted November 4, 2010 #1 Posted November 4, 2010 Q1-Does the Lower Front Vent on an 83 VR fit on an 89 VR? Q2-Are the actual vents interchangable?
Grisolm1 Posted November 4, 2010 #2 Posted November 4, 2010 Leg vents in front of your shins? I'm "pretty" sure both vent and whole assembly are same. Someone else should probably confirm this. Vents in side panels are different but the whole side panel is interchangeable.
GolfVenture Posted November 4, 2010 Author #3 Posted November 4, 2010 Thank You. I'm interested in an ebay item.
Dragonslayer Posted November 8, 2010 #4 Posted November 8, 2010 Q1-Does the Lower Front Vent on an 83 VR fit on an 89 VR? Q2-Are the actual vents interchangable?Yes they are the same and actually the left and right vent louvers are interchangeable by turning one of them upside down.
