this is what i had left after 21.3k miles......
On the next set reverse those pads at about 10k miles and then you will have even wear on each and longer life.
just my :2cents:
I always keep the best of the two just in case I get caught on a trip and suddenly realize one of the pads is totally gone. Takes about five minutes to change it out.
Everybody says to reverse the pads. Everything I have ever been taught, is to never do that. The friction always going in one direction, and then when you reverse that friction, could result in the pad exploding....
Hey Dave,
Far be it from me to try to change your mind about something that makes you feel "warm and fuzzy" about the brakes on your bike, and my dad had the same opinion when he worked on his brakes, but because the friction material is no longer riveted to the backing plate, it is "bonded" (epoxy glued) you should be able to swap the pads from side to side as long as the brake pads were not overheated. This would be evident by a blued up rotor. As with many things pertaining to your motorcycle, this is a personal preference. If money isn't an issue, then by all means, install new pads every time. If your handy with a wrench, and take a few minutes to swap the pads, you will get more mileage out of them with few, if any problems, as long as the caliper is functioning properly.
Just and "FYI".
Earl
just my :2cents:
jb,
i swapped them side for side at approx. 12k miles.
skydoc17,
thank you for getting me the rear pads so quickly and also for the great phone conversation that we subsequently had......FWIW to our member....Earl is very knowledgeable on our bikes and is very user friendly....hats off to Earl
:thumbsup::thumbsup::thumbsup::clap2:
I had the same issue twice
Heat is the problem
The following article helped
http://www.moccsplace.com/images/brakes/inpad.htm
After the second time I just put a little less brake fluid in
I run it just under the mark it leaves room for the fluid to expand when hot
and not put pressure on the pads
Still plenty of stopping power
This is the third summer no problems I do pull a trailer on every trip
no problem stopping
43,000 miles on an 06 RSTD 30,000 of it no brake troubles
Worked 4 Me
Be safe:thumbsup2:
Edited by dave_wells
forgot something
Heat is the problem
no problem stopping
Worked 4 Me
Be safe:thumbsup2:
Dave,
thanks for that article............
Yammer,
i hear the first gens don't actually go fast enough to require brakes.....
:Laugh:
Hey Buz,
Thank you very much for the kind words. It is always a pleasure to help a fellow VR.ORG member! One of the best things about this site is the way we help each other. I have learned so much, and made so many friends on this site, that the value of the $12.00 I spend every year is unmeasurable. :thumbsup2:
Ride Safe,
Earl
Dave,
Yammer,
:Laugh:
Only need them to slow down and wait for the 2nd Gens to catch up!!:whistling:
