Mariner Fan Posted October 30, 2010 Posted October 30, 2010 I had to replace a burned out bulb for my passing lamps and was reminded what a junky set up they are. Has anyone replaced the passing light buckets with something better? Perhaps something that can be adjusted without removing the bulbs? I'm good for another year or so until these bulbs burn out but I wouldn't mind finding a better set up to mount on my light bar.
waterbug Posted October 30, 2010 Posted October 30, 2010 I can't remember who all makes them but there are some led passing lights out there. I know custom dynamics makes stuff and ther are piaa and I'm sure others that are a lot cheaper. Good luck buddy!
N3FOL Posted October 30, 2010 Posted October 30, 2010 I read your post and came across this thread not too long ago discussing LED passing lamps and the issue of static on the radio. After reading the static issue, I shied (sp.?) away from these units for now. The static complaints may be isolated, but it may also be an issue on my RSV. Anyway, the price is not bad for $40 bucks. http://www.venturerider.org/forum/showthread.php?t=53973&highlight=passing+lamps
Mariner Fan Posted October 30, 2010 Author Posted October 30, 2010 I'm actually talking about the hardware, not the lights.
Squidley Posted October 31, 2010 Posted October 31, 2010 Hate those driving light buckets! I know exactly what your saying Bob, you cant adjust them without removing the light from the bucket. I had a set of adjures that I got off BuddyRich on my '08 that could be adjusted outside on the mount. I will be looking for something like that with the '99 when I get her back together. If I locate something I'll post it up.
ken Posted October 31, 2010 Posted October 31, 2010 I was just getting ready to order LED rear turn signals and taillight. I there an issue with LEDs and radio static? I read your post and came across this thread not too long ago discussing LED passing lamps and the issue of static on the radio. After reading the static issue, I shied (sp.?) away from these units for now. The static complaints may be isolated, but it may also be an issue on my RSV. Anyway, the price is not bad for $40 bucks. http://www.venturerider.org/forum/showthread.php?t=53973&highlight=passing+lamps
N3FOL Posted November 1, 2010 Posted November 1, 2010 Hello ken. As fas as I know and according to the thread, some owners have been experiencing radio static when they install the LED passing lamps as was discussed on the link. LEDs for running tail and signals, I've never experienced static problems considering I have LEDs on my running front, rear, and taillight including the HD auxilliary light that has been fitted with Red LED lights. It may be just a problem with LED passing lamps from the vendor.
bmxndad Posted October 3, 2012 Posted October 3, 2012 What is the bulb # for the Yamaha brand passing lights? Thanks, Ross
XV1100SE Posted October 3, 2012 Posted October 3, 2012 Sealed beam replacement light bulb - STR-4NK35-50-00 $18.95 Yamaha has a halogen one as well but not sure if you need a lens for it as well. STR-4NK35-50-01. Replacement H3 lens STR-4NK35-17-01 I went with GE H7616 bulbs as replacement - a LOT brighter than the stock bulbs. You can put in a 4" H3 sealed beam "bulb".
Seaking Posted October 4, 2012 Posted October 4, 2012 Hello ken. As fas as I know and according to the thread, some owners have been experiencing radio static when they install the LED passing lamps as was discussed on the link. LEDs for running tail and signals, I've never experienced static problems considering I have LEDs on my running front, rear, and taillight including the HD auxilliary light that has been fitted with Red LED lights. It may be just a problem with LED passing lamps from the vendor. The first set of LED passing lamps I installed were horrible for interference on the radio, horrible! The next set I picked up were from Custom Dynamics and there is no interference on the radio or aux at idle or at speed. These lamps are a little expensive but as I found out, they are cheaper than others, more expensive than than the cheap brands but no interference. I've had them on the bike for 2 years or so without any probs.. Custom Dynamics is a great company to deal with if you encounter any probs.. Very bright and solid.. they go well with a HID headlight...
dacheedah Posted October 4, 2012 Posted October 4, 2012 Ok, I read that the led's can cause a harmonic loop that causes the radio interference, so wouldn’t some diodes break the loop??
Seaking Posted October 5, 2012 Posted October 5, 2012 Ok, I read that the led's can cause a harmonic loop that causes the radio interference, so wouldn’t some diodes break the loop?? Not sure to be honest.. it's all FM to me..
