uechi kid Posted October 26, 2010 #1 Posted October 26, 2010 I'm helping a Friend add the Kisan vectraLight - Brake Light and Turn Signals to his 08 Electra Glide Classic. I'll need to splice into the existing run, turn and brake wiring. To simplify this, Does anyone happen to know what the color code for these wires are? Thanks, Rich
rentalguy1 Posted October 26, 2010 #2 Posted October 26, 2010 Not sure if this will help or not: Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit http://a1276.g.akamai.net/7/1276/734/94fb0c3ed8a8f9/resource.harley-davidson.com/media/images/hd/common/hd_spacer_e204.gif Turn signal module adds an auxiliary brake light and running light function to your existing turn signals for auxiliary rear lighting. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements. http://a1276.g.akamai.net/7/1276/734/94fb0c3ed8a8f9/resource.harley-davidson.com/media/images/hd/common/hd_spacer_e204.gif http://a1276.g.akamai.net/7/1276/734/e51c98c8448d2e/resource.harley-davidson.com/media/images/holiday2003/spacer_cccccc_1a21e.gif To disable the running lights so that the signal lights only come on with the brake lights is a relitivly easy fix when you look at the modulator there is a male connection a female connection and the modulator it's self/ Cut the 2 blue wires leading into and out of the modulator, and join these two wires togeather. Join the reamining 2 blue wires so that the modulator is bypassed. Cut the Red and Yellow wire between the modulator and the female side. Join the Red /yellow wire with the two blue wires from the modulator thats it no more running lights, just brake and signal. More here
