XV1100SE Posted October 24, 2010 Posted October 24, 2010 I know oils have been discussed before but based on a couple locally available oils and an '09 Venture, which one would you use? I know a couple are automotive oils but some people say they are okay to use. Our local Canadian Tire has : - Rotella - don't remember the description but think it was 15w-40 - Castrol GTX 10W-40 (anti-sludge formula) http://www.castrol.com/castrol/genericarticle.do?categoryId=82915464&contentId=6003410 - Quaker State 10w-40 SAE Peak Performance (Advanced Durability) http://www.quakerstate.com/#/motor-oil/advanced-durability - Motomaster Formula 1 10w-40 (premium 4 stroke) - $5/litre - Mobil 1 MX4T 10w-40 - $17/litre (http://www.mobiloil.com/USA-English/MotorOil/Oils/Motorcycle_Oil_FAQs.aspx#FAQs2) Amsoil Synthetic motorcycle oil - 10w-40 - $20/litre (http://www.syntheticoildealer.com/royle/dyno.htm
dingy Posted October 24, 2010 Posted October 24, 2010 http://i1007.photobucket.com/albums/af193/gdingy101/kangaroo.gif
camos Posted October 24, 2010 Posted October 24, 2010 Likely totally irrelevant to your Venture but I use the Rotella 15w 40 in my Virago 1100 SE. I want some popcorn too.
Santa Hal Posted October 24, 2010 Posted October 24, 2010 I use the Rotella 15w 40 in my 09 Venture Hal
Freebird Posted October 24, 2010 Posted October 24, 2010 Mobil 1 MX4T 10w-40 Been using it in my '99 since '99. Though I it's called racing 4T or something like that now. They changed the name here a couple of years ago but still the same oil.
gunkylump Posted October 24, 2010 Posted October 24, 2010 (edited) I've used the Amsoil, nothing wrong with it, but I switched to the Mobil from Crappy Tire a couple of years ago and I really think the bike is quieter(chirp chirp). Turned over 100,000 k's on our trip to Texas in September........ gunk:smile5: Edited October 24, 2010 by gunkylump
Monty Posted October 24, 2010 Posted October 24, 2010 Rotella in my '03 RSV. Just rolled over 70,000 miles.
hig4s Posted October 24, 2010 Posted October 24, 2010 I would avoid the Quaker State, not sure about the Motomaster, but the other four are good oils, provided the Castrol is not labeled "energy conserving" on the back.
Kirby Posted October 24, 2010 Posted October 24, 2010 Mobil 1 Fully Synthetic 15w-50 has been in my RSV(33,000 miles) and VMAX(37,000 miles) since I bought them.
BEER30 Posted October 24, 2010 Posted October 24, 2010 I'm dumping the Rotella and going to Castrol. When my VIP expired, I switched to Rotella from Yama-Lube. Clutch started slipping, running warmer and now consuming oil somewhere. Tipped over 68K on my '06 now. BEER30
First_N_Last Posted October 24, 2010 Posted October 24, 2010 I am using & continue to use Rotella Synthetic T6 oil. The 1st change flushed a lot of setiment out of the engine... reduced engine noise... better clutch friction. Works better than Amsoil in my 2008 RSV with 30k on it. I change every 5k. Nothing but a winner for me! JohnB
XV1100SE Posted October 25, 2010 Author Posted October 25, 2010 Thanks for the info and suggestions. I went with the Mobil 1 MX4T 10w-40 since I felt more comfortable that it is labelled as a motorcycle oil. The Rotella was on the shelves with the automotive oils.
Mariner Fan Posted October 25, 2010 Posted October 25, 2010 (edited) I'm dumping the Rotella and going to Castrol. When my VIP expired, I switched to Rotella from Yama-Lube. Clutch started slipping, running warmer and now consuming oil somewhere. Tipped over 68K on my '06 now. BEER30 Interesting! Seems we all have different experiences with oil. My first oil change was to Yamalube Full synthetic 15w-50. Noticed that that bike was much quieter and shifting was smoother. When it was time to change the oil again I went back to the dealership and found that they didn't have the Yamalube anymore. They recommended that I use Spectro Full synthetic 20w-50. They even claimed it was better than the Yamalube. Well, the bike was noisier and shifting was clunky. Won't use that anymore! This round I tried Mobil 1 Racing 4T 10W-40. Much better than the Spectro but still not as good as the Yamalube. It's pretty close though, and I'll probably just stay with the Mobile One. I may try the 15w-50 though. Edited October 25, 2010 by Mariner Fan
waterbug Posted October 25, 2010 Posted October 25, 2010 I used the rotella in the blue jug last time with 15w40w and changed it not long ago and put rotella t5 the blend 10w30w since it's going to get colder out. The whine is louder and it shifts into 3rd with a clunk but other than that it's fine. I just turn the radio up and I'm half deaf anyway so Im good I guess.
Yammer Dan Posted October 25, 2010 Posted October 25, 2010 (edited) Castrol GTX 20/50 for the last 45 years. Never had a oil related problem!! Edited October 28, 2010 by Yammer Dan
hig4s Posted October 25, 2010 Posted October 25, 2010 Interesting! Seems we all have different experiences with oil. My first oil change was to Yamalube Full synthetic 20w-50. Noticed that that bike was much quieter and shifting was smoother. When it was time to change the oil again I went back to the dealership and found that they didn't have the Yamalube anymore. They recommended that I use Spectro Full synthetic 20w-50. They even claimed it was better than the Yamalube. Well, the bike was noisier and shifting was clunky. Won't use that anymore! This round I tried Mobil 1 Racing 4T 10W-40. Much better than the Spectro but still not as good as the Yamalube. It's pretty close though, and I'll probably just stay with the Mobile One. I may try the 20w-50 though. 20w-50 Mobil 1 is specifically designed for air cooled twins.
Mariner Fan Posted October 25, 2010 Posted October 25, 2010 20w-50 Mobil 1 is specifically designed for air cooled twins. I wrote the wrong weight. It was 15w-50.
waterbug Posted October 26, 2010 Posted October 26, 2010 Going to get a little cold for the thicker oil I would think Bob but not sure. I decided to try a little thinner oil for this winter but we will see how that works out and if I change it out.
BradT Posted October 27, 2010 Posted October 27, 2010 Castrol 20/50 for the last 45 years. Never had a oil related problem!! Me Too, just not that long. I just turned 45 in September. Brad
N3FOL Posted October 27, 2010 Posted October 27, 2010 Another Rotella 15W40 over here and it is still in the engine and good for another 2000 miles more. I have Valvoline 10W40 moto oil sitting in the garage and I may very well use that on my next oil change for winter riding. I recently moved to Rotella and Purolator Gold and am very happy with the recommendation by members.
jpbragwell1215 Posted October 27, 2010 Posted October 27, 2010 (edited) :smile5:The 1st owner of my 2001 RSTD said he only used the yamalude oil. However, I like the synthetic blend, so I am now trying the Honda HP4 high performance 10w-40 synthetic blend motorcycle oil. After 2K miles, I am very pleased. Shifting very good, and "seems" to be running a touch quieter. Just another thought to ponder! :sun1: Edited October 28, 2010 by jpbragwell1215
91nwl Posted October 27, 2010 Posted October 27, 2010 :smile5:The 1st owner of my 2001 RSTD said he only used the yamalude oil. However, I like the synthetic blend, so I am now trying the Honda HP4 high performance 10w-40 synthetic blend motorcycle oil. After 2K miles, I am very pleased. Shifting very good, and "seems" to be running a touch quieter. Just another thought to ponder! :sun1: Yamalube is a 10W-40 synthetic blend.
