Guest Kemo Posted October 21, 2010 #1 Posted October 21, 2010 Can someone tell me how to adjust the headlight on my 1999 RSV? I know how to adjust it up and down, But need info on side to side. As of right now the head light is aimed more to the far left than normal. Also do I need to split the fairing to do this?
V7Goose Posted October 21, 2010 #2 Posted October 21, 2010 Yes, you will have to split the fairing. You will find an adjustment on the side of the headlight frame. Goose
Gary N. Posted October 21, 2010 #3 Posted October 21, 2010 (edited) If you turn the bars to the far right you can see the adjustment knob on the left side of the triple tree. There's another adjustment on the right side that you need a Phillips screw driver for. Turn the bars to the far left for this one. Aim the light on a wall or garage door with the forks centred to see what needs to happen. You will probably have to use a combination of both adjustments to get it right. I didn't have to split the fairing to adjust mine. Edited October 21, 2010 by Gary N.
Guest Kemo Posted October 21, 2010 #4 Posted October 21, 2010 Gary, Found the adjustment screw you mentioned on the right side. Worked great, Thanks so much Now if you where replacing the bulb. What would you go with silver light or Zeon?
V7Goose Posted October 21, 2010 #5 Posted October 21, 2010 If you turn the bars to the far right you can see the adjustment knob on the left side of the triple tree. There's another adjustment on the right side that you need a Phillips screw driver for. Turn the bars to the far left for this one. Aim the light on a wall or garage door with the forks centred to see what needs to happen. You will probably have to use a combination of both adjustments to get it right. I didn't have to split the fairing to adjust mine.That's interesting - I hadn't seen that screw before. It actully looks like another height adjustment - very different than the side adjustment screw I remember on the headlight frame. But if it works lateral adjustment, that is great - glad you know about it! Goose
Seaking Posted October 21, 2010 #6 Posted October 21, 2010 Gary, Found the adjustment screw you mentioned on the right side. Worked great, Thanks so much Now if you where replacing the bulb. What would you go with silver light or Zeon? Go with a $60 single bulb double action HID kit.. BRIGHT doesn't come close to describing how bright these are..
Guest Kemo Posted October 21, 2010 #7 Posted October 21, 2010 Gary,If you don't mind can you send me the info on where to get the kit, Just private message me Thanks again for the help.
Gary N. Posted October 21, 2010 #8 Posted October 21, 2010 Gary, Found the adjustment screw you mentioned on the right side. Worked great, Thanks so much Now if you where replacing the bulb. What would you go with silver light or Zeon? I've only ever used the Silver Star bulb.
rwrenn1 Posted October 21, 2010 #9 Posted October 21, 2010 Go with a $60 single bulb double action HID kit.. BRIGHT doesn't come close to describing how bright these are.. more info???????
KeithR Posted October 22, 2010 #10 Posted October 22, 2010 Some info on HID headlights........ Keith http://canadiancruisercustomizing.com/index.php?main_page=index&cPath=3&zenid=st510km33udfd27ljg76756es7
Dave77459 Posted October 22, 2010 #11 Posted October 22, 2010 Some info on HID headlights........ Keith http://canadiancruisercustomizing.com/index.php?main_page=index&cPath=3&zenid=st510km33udfd27ljg76756es7 That kit died for me after flickering a few times. CCC said I needed a bigger fuse to send more juice to the ballast, but the existing fuse didn't pop? Not sure how adding a bigger fuse would help, since the existing one was ample. Whatever. I went back to the same Silverstar Ultra that I'd been using for a couple years. It was almost as bright anyways when both were aimed properly. I know that particular HID kit worked well for others, and I know some people diss the Silverstar (but maybe not the Ultra), so there is not a one-size-fits all answer. I'm glad people have options. Dave
Richie R Posted October 22, 2010 #12 Posted October 22, 2010 Here is another place for headlight options. http://www.ddmtuning.com/ We use the 35w in our snowmobiles. It is the slim ballast kit Iam refering to. Going to get a kit for the bike. Richie R
