russellohioboy66 Posted October 17, 2010 #1 Posted October 17, 2010 hello everyone, I have a problem with my 2000 venture. I just got the bike a few weeks ago. It was running ok but not perfect. and so i pulled off the carburetors and cleaned all the jets which were clean. i ran seafoam through it for 2 tanks. i found 2 slider diaphrams with holes in them. so i replaced them and put the bike all back together and now it is backfiring out of right side exhaust pipe. i had a problem with the right front pipe cold at idle. so i pulled the carbs back off and checked them again and all looks to me ok. so i tried to sync the carbs and i can sync 3 of the four. i am using a carbtune sync tool and the right front carb has full vacuum all the time. i can adjust the left side and right rear cylinder. i am not sure why i have full vacuum all the time. i drove the bike today and it runs great full power (surprised me on how much power the bike has) but if you start the bike and crack the throttle alittle. it will pop and backfire out the right tail pipe. but im at a lose here and not real familiar with multi carb bikes. my other bike is fuel injected. any help would be appriciated. thanks mike
wes0778 Posted October 17, 2010 #2 Posted October 17, 2010 (edited) 1st thought, are you using the carb sync procedure in the official Yammie service manual? I is WRONG. Use the SEARCH here to find kbran's excellent write up on the proper way to sync the carbs. Aw, heck, here's the link; http://venturerider.org/forum/showthread.php?t=258 Edited October 17, 2010 by wes0778 added the link
russellohioboy66 Posted October 17, 2010 Author #3 Posted October 17, 2010 i was going by the manual and i just read the link and i am going to re sync them in the morning. thanks for your help. ill update tomorrow.
russellohioboy66 Posted October 17, 2010 Author #4 Posted October 17, 2010 ok, i finally got the carburetors synced. it runs awsome now. like a new bike. i do have one other issue with the bike and i think that is all that is wrong with it. when i ride it i hear a sh sh sh noise coming from around the final drive. any ideas? thanks for all your help.
Seaking Posted October 17, 2010 #5 Posted October 17, 2010 russellohioboy66 said: ok, i finally got the carburetors synced. it runs awsome now. like a new bike. i do have one other issue with the bike and i think that is all that is wrong with it. when i ride it i hear a sh sh sh noise coming from around the final drive. any ideas? thanks for all your help. Could just be the brake pads on the disc.. I heard that before and could only pin point it but rolling along and shutting off the bike.. all I could hear was the sh sh sh.. usually the rear inside brake pad as it always has some slight amount of contact with the brake disc, hence why it wears out twice as fast as the outside pad.
Mikey Posted October 18, 2010 #6 Posted October 18, 2010 russellohioboy66 said: ok, i finally got the carburetors synced. it runs awsome now. like a new bike. i do have one other issue with the bike and i think that is all that is wrong with it. when i ride it i hear a sh sh sh noise coming from around the final drive. any ideas? thanks for all your help. Russel, it sounds dumb but I had the exact same noise in my 99 and turns out I only had 20lbs of air in the rear tire. Put air in and the noise went away.
russellohioboy66 Posted October 18, 2010 Author #7 Posted October 18, 2010 i checked the tire and its ok. so i jacked up the bike and rotated the tire and it is clicking. i think the splines are dry from wheel to final drive. i am going to pull off the rear wheel and check them. thanks mike
