  Condor said:
I've had a few issues with Valero in the past, like short pouring a gallon. The only reason bad gas gets to the tank is they don't run it through a filter and water seperator. It could be that they're not maintaining them.... ???
I agree with Condor...on the stores equipment and tank maintenance. I doubt they have bad fuel, they get it from the same terminals as every one else (plus or minus additives). As someone else may have said, I don't buy gas when I see a fuel tanker dumping fuel. They're (tanker driver) is supposed to check the water level in the tank before unloading. I think it used to be around 3-4" of water when they had to pump it out. Most tanks probably have 1-2" of water in them at the bottom.
  Marcarl said:
I won't buy from them anymore,,,,,,, does that help????
Carl they own Ultramar up here, there is a few of these stations by you.
Brad
