The Browner keeps on going and going and going...and now it's
FOR SALE...
NO reasonable offer will be refused.
I'm giving someone else the chance to get the Venture smile with a minimal investment.
You will ride a rattle free bike thanks to "living room" maintenance done by a perfectionist who took 100s of pictures to prove every job.
Seriously interested parties can PM me for a long list of upgrades and OEM new parts installed in the last 4 years, including in the last 6 months:
new clutch plates on a PCW racing kit
a complete carb rebuild including gaskets and diaphrams.
and a new throttle cable
FOR SALE...
Hey just because you missed us by about 5 min at the fireside restaurant Sat, is no reason to get sore and sell your scoot.
:rotfl::big-grin-emoticon::thumbsup2:
FOR SALE...
Hey Swifty, just in case, if you are going to WING it.
Better check to see if the WING will fit through the door, before buying (and ramp will hold it). :bang head::mo money:
I just can't see you, with a 2nd gen. :2cents:
Hey Dave Thanksgiving dinner with the in laws, did you decide to do sell the bike and buy a ring ? ? :sign isnt that spec
:stirthepot:
BRad
yeah, 10 10 10, a great day to get married...if I'm not "getting lucky" riding this beautiful 1st generation Royale I might as well let someone else have a go at it.
Now that I've taken a look at my records over the last few years and put the actual list together...wow...I might be getting cold feet...
2 new tires, currently have less than 4,000 km on them,
plus a spare new Avon Venom rear tire
all throttle cables have been replaced, one of them several times (what gets used the most wears out the fastest!):banana:
8 new clutch friction plates with PCW Racing kit
new rear header heat shield
carb rebuild…new diaphragms, new gaskets, professionally cleaned
valve adjustment (all have been done once, Excel spreadsheets showing results)
exhaust collector box rebuid on a new one that was purchased in 2006
new thermostat housing, seal and automotive thermostat
coolant drain plug refurbished and new seals added
both handle bar switches dismantled and cleaned
new starter clutch
new heavy duty stator
new rear brake caliper
new upper and lower steering head bearings with races
new speedometer (reads approx. 123,000 less than the real mileage)
while dash panel apart to do the speedo all the instrument bulbs were replaced with new
new Vmax starter
front brake calipers rebuilt last year
battery indicator bypass for dry cell battery installation
trunk rack purchased on EBay and installed
lighter outlet installed to run GPS and air pump
all coolant hoses have been replaced
new rear wheel bearing
new valve cover gaskets
new desiccant replaced in air suspension pump
E4 error solder repair completed
4 solid motor mounts installed to front end of engine
new Firestik antennae
new Progressive front springs
new left fork tube, new fork seals
Modulite 4-wire trailer kit, hitch came with the bike
new spark plug wires
new heavy duty battery cables
new Clearview windshield, 22” tall, and slightly wider than stock
Purchased December 2005 with 54,000 kms
Edited by Swifty
If you didn't get lucky,,,, why would you wish it on someone else?
By the way, that scoot is worth what ever you pay for it!
That's if you like riding. If it the other reason, best get a crotch rocket.
