Hello! I just purchased a 1983 Venture and when I rode it home the idle stuck at about 2500. The bike starts and runs fine, but the idle will not slow down. Any suggestions?
You can try and ajdust the idle screw. Remove the left side cover. It is the downward pointed screw between the two sync screws. You should be able to turn it by hand - you don't need a screwdriver, but pliers may help to start it. Turn the idle screw counter clockwise and see if your idle goes down. Make sure you don't adjust the sync screws!!! (These need a screwdriver).
Please look at attached photo
Thanks much! Found it and adjusted it down. Went for a long great ride (it was GORGEOUS today in northeast Ohio). That seemed to take care of it. Thanks again!:clap2:
I'd get some Sea-Foam in it soon. Something caused that idle to mess up. Spray some WD40 around the carbs to see if you have a vacum leak. It will rev up if you do.
