Marcarl Posted September 21, 2006 #1 Posted September 21, 2006 I'm not to smart when it comes to electronics, but logic tells me that this should be possible. I have an 85 VR with the radio\cassette, and intercom but no CB. I also have a Uniden Pro 510xl CB with a Mic-Master 'hands free' mic attachment that gives me the push to talk button. (these are used by truckers, mic on the ear, PTT on the gear shift, and takes the place of the mic on the CB). Can I wire all this into the bike amp to make it work through the intercom speakers and mic?
Gary N. Posted September 21, 2006 #2 Posted September 21, 2006 Carl, Most CB's have an external speaker port. Either attach another speaker somewhere or maybe use this port to hook into your AUX port on your bike. Do those antiques have an AUX port?? But if you hook it to the AUX port you won't be able to hear anything on the radio or cassette, just the CB.
Marcarl Posted September 21, 2006 Author #3 Posted September 21, 2006 My CB has an external speaker jack, and my scoot's radio has a CB input, so it should be fairly simple for someone who knows, and that's where I don't get it.
Marcarl Posted September 23, 2006 Author #4 Posted September 23, 2006 Still trying to do this, any ideas?
Denden Posted September 23, 2006 #5 Posted September 23, 2006 I don't know if this helps, but...I have a '83 Venture Standard. I installed a Uniden 520xl. I made a "push-to-talk" push button that activates a relay, that I wired into what used to be the microphone push to talk button ( I removed the hand held microphone, and used the wires). So my headset microphone goes to what used to be the handheld microphone wires ( thru the usual headset plugs ), and the Uniden's external speaker jack goes to my headset speakers. I used to have a handbar switch that would switch from the headset speakers to a small external speaker on the handlebars, but I removed it since I always use the headset. I also hooked up another headset plug for the rear seat, with another push to talk button, and made the speaker connections in series. That means both me and my wife can hear incoming, and hear what the other is transmitting. So we use the CB as an intercom, by just going to an empty channel, and using each of our own push to talk buttons to transmit to an empty channel, but the other can hear the transmission, so it is our intercom, but we have to be careful because out intercom talk is actually being transmitted to an empty channel.
Marcarl Posted September 23, 2006 Author #6 Posted September 23, 2006 Denden said: I don't know if this helps, but...I have a '83 Venture Standard. I installed a Uniden 520xl. I made a "push-to-talk" push button that activates a relay, that I wired into what used to be the microphone push to talk button ( I removed the hand held microphone, and used the wires). So my headset microphone goes to what used to be the handheld microphone wires ( thru the usual headset plugs ), and the Uniden's external speaker jack goes to my headset speakers. I used to have a handbar switch that would switch from the headset speakers to a small external speaker on the handlebars, but I removed it since I always use the headset. I also hooked up another headset plug for the rear seat, with another push to talk button, and made the speaker connections in series. That means both me and my wife can hear incoming, and hear what the other is transmitting. So we use the CB as an intercom, by just going to an empty channel, and using each of our own push to talk buttons to transmit to an empty channel, but the other can hear the transmission, so it is our intercom, but we have to be careful because out intercom talk is actually being transmitted to an empty channel. Interesting setup, might try it if I don't have any luck going throught he bikes intercom. Thanks
scotty Posted September 17, 2007 #7 Posted September 17, 2007 There seems to be a lack of info on the CB connector on the tuner. I have found some of the pinouts. You can find them here http://www.delusional-mechanic.com/ Click on yamaha ham install I havn't got all of the bugs out yet but mabey this winter. I hope this can help someone.
PEIslander Posted September 17, 2007 #8 Posted September 17, 2007 Hey Marcarl, check out this link in the tech library http://www.venturerider.org/forum/showthread.php?t=499 It may be what you're looking for.
Marcarl Posted September 17, 2007 Author #9 Posted September 17, 2007 Thanks for all the info, cold weather is coming, the scoot will be in for a total check up and then maybe we'll also get rid of all that static on the CB and radio. Still 3+ months to go til January, so until then it's status quo.
Gearhead Posted September 19, 2007 #10 Posted September 19, 2007 Marcarl, My dad has a Kawi Voyager on which the Intercom is standard but the CB is optional and his doesn't have it. We found a guy on the web who has done just what you want to do on his Voyager - wired a standard CB into the factory intercom system. Of course the Voyager's system is not exactly the same as the Venture's, but the concept is the same. It involves a handful of electronic parts you can order from Radio Shack's website. He ordered the parts and we laid them out on the little breadboards, but haven't soldered it together yet. The guy is an electrical engineer and says it works on his bike just like the factory system does. I attached his very complete schematic and some info I compiled on mic pinouts. Maybe it can be adapted. Jeremy
