AKRefugee Posted October 7, 2010 #1 Posted October 7, 2010 Discovered the other day that my flashers only work on the left side. All turn lights work on right side and left side but when I turn on only the flashers only the left sides work. Any ideas?
MikeWa Posted October 10, 2010 #2 Posted October 10, 2010 The hazard relay has separate outputs for the left and right. Right is a green wire and left is a purple I think. Use a test light to check each output. Mike
AKRefugee Posted October 11, 2010 Author #3 Posted October 11, 2010 Thanks Mike. I will check that out.
