1BigDog Posted October 5, 2010 #1 Posted October 5, 2010 Since winter will be upon most of us soon enough I was just wondering on your plans (if any)for the bike this winter. In January, when winter really sets in here, I plan on pulling down the front end and polish the forks and trees. Thats something I have wanted to do for a while. The lower legs look like crap right now. While the fairing is off and if the money holds out I might go ahead and install the new gauge set-up from Ponch. I like the tach in there better then the three gauges originally offered. Also may rebuild my driving lights using LED bulbs instead of the incandescents and rewire the whole thing. Price is a concern though since the cost of each bulb is 112 bucks. Maybe by then I can find a cheaper set. Flanders G2 bars and extended SS throttle cables might make it into the mix this time too. That should just about wrap up the mods to the bike for a long time to come. Yea, righttttt:smile5:
mini-muffin Posted October 6, 2010 #2 Posted October 6, 2010 Ok the guy that lives in Florida is wondering what to do during the winter. That's funny. Ruffy we ride all year long up here, you guys in Florida are getting soft. Margaret
Panjandrum Posted October 6, 2010 #3 Posted October 6, 2010 I plan on riding through the winter, like I did last year... unless this winter is like the one before last when snow stuck around for two months. Fingers crossed that the snow behaves, and stays on the mountains! (Yes, I am in Canada, but in the warm part!)
Trader Posted October 6, 2010 #4 Posted October 6, 2010 (edited) First....I have to finish insulating and putting a heat source in the garage.(I'm NOT in the warm part!) Then for the bikes..... I plan on taking the best of the 2 bikes (the 83 VR "Blonde" and '84 Standard "Red")and putting those parts into my blonde...but make sure Red is stilll a decent bike for resale. The clutch in Red is slipping. So I'm going to take good clutch out of blonde and put in Red. Then put Skydoc clutch upgrade into Blonde put progressives in front forks of Blonde Dingy's starter ground upgrade on both install condor Brace on Blonde put new tires from Red onto Blonde take back rest from red and put on Blonde figure out how to mount '86 arm rests on 83 Blonde repair various plastic cracks, tabs etc Paint for both take upgraded stator out of Red and put into Blonde stainless brake lines and possible delink for Blonde solid motor mounts for Blonde heavier battery cables for Blonde move TCI to top of airbox on both battery sensor/resistor mod on Blonde (already done on Red) Replace/repair odometer on Red repair small exhaust leak on Red replace carb diaphrams on Blonde re-cover or repair split at front seam of both seats purchase needed cables & headsets to actually use driver/rider intercom replace speakers in Blonde R&R and lube rear end and driveshaft on both Plus clean and polish everything I can! Other than that...not much! :mo money: Edited October 6, 2010 by Trader
ken Posted October 6, 2010 #5 Posted October 6, 2010 Once the low 30's set in I plan on............ 1) Installing stock pipes .........selling the Khrome Werks:whistling: 2) Reversing the Jason Mod "if I can figure it out." 3) upgrading to 401 Polk speakers 4) Stock Mirrors 5) Cutting down the stock shield so that I can see over it. 6) Making the touring pack removable so that I can go starglide. 7) Maybe a carb sync (never none this one before, shouldn't be to hard) 8) Dechroming:shock3: 9) and planning my next trip
eusa1 Posted October 6, 2010 #6 Posted October 6, 2010 ken said: Once the low 30's set in I plan on............ 1) Installing stock pipes .........selling the Khrome Werks:whistling: 2) Reversing the Jason Mod "if I can figure it out." 3) upgrading to 401 Polk speakers 4) Stock Mirrors 5) Cutting down the stock shield so that I can see over it. 6) Making the touring pack removable so that I can go starglide. 7) Maybe a carb sync (never none this one before, shouldn't be to hard) 8) Dechroming:shock3: 9) and planning my next trip whats # 8??? i don't understand? and # will go out in the morning!
eazyduzzit Posted October 6, 2010 #7 Posted October 6, 2010 I plan on riding all winter, except for the teens and 20s days.
ahoutzer Posted October 6, 2010 #8 Posted October 6, 2010 I plan on going to work / church / store and other places every day, just like at any other time of year. I cant stay at home just because it's cold,so I'll ride every day, as usual. I do plan to wear more layers of clothes.
Trader Posted October 6, 2010 #9 Posted October 6, 2010 ahoutzer said: I cant stay at home just because it's cold,. How about when it's cold, icy and 2 feet of snow?
ahoutzer Posted October 6, 2010 #10 Posted October 6, 2010 Snow and die would be diffent. We get one or two days of that per year. In Jacksonville, Florida -- very unlikely.
Gary N. Posted October 6, 2010 #11 Posted October 6, 2010 I'm going to load the bike into the trailer and head south. Maybe even Florida but Texas for sure in Feb. I'll need to change the oil first though.
Flyinfool Posted October 6, 2010 #12 Posted October 6, 2010 My plans for winter in order. 1. Ride till the snow is too deep to be able to get the bike out of the shed. 2. Build my receiver hitch. 3. Build accessories for new receiver. 4. Build trailer to pull. 5. Add 2nd bad boy horn. 6. Add more lights to bike. If time and budget allow # 5 may turn into replacing bad boy air horn with real train horn. I also like Kens #8 above, dechromeing. I hate chrome. (flame suit on)
dingy Posted October 6, 2010 #13 Posted October 6, 2010 ken said: 2) Reversing the Jason Mod "if I can figure it out." If it is the standard "Jason" mod, it is a simple undo. You will need 3 rubber plugs that fit over the sync ports on the carb boots. (3/16" I think) Remove the 4 interconnected hoses between the carbs. Plug the hose that goes up to vacuum sensor into #2 (Left Front) carb intake boot. Plug three remaining ports on intake boots with rubber plugs. Gary
Freebird Posted October 6, 2010 #14 Posted October 6, 2010 I THINK Ken rides a second gen. It is a bit difference. I think he will need two of the vacuum caps and there is a hose on each side that would hook to the other port on each side. They go to the AIS system.
ken Posted October 6, 2010 #15 Posted October 6, 2010 Freebird said: I THINK Ken rides a second gen. It is a bit difference. I think he will need two of the vacuum caps and there is a hose on each side that would hook to the other port on each side. They go to the AIS system. From what I can tell the PO removed the AIS system. He installed an air horn in it's place. I can see three or four hoses pluged off hanging off the bottom.
Freebird Posted October 6, 2010 #17 Posted October 6, 2010 All RSVs have the 4 hoses hanging out the bottom. They are various drains and should not be plugged off. They have nothing to do with the AIS system. If the AIS truly has been removed, all you have to do is remove the tubes connecting the front and rear carb boots and replace them with 4 caps. Very simple.
BradT Posted October 6, 2010 #18 Posted October 6, 2010 Clean it up and put it away until March or April Then go to Swifty's with Coffee and watch him tear apart a first gen. Brad
oldgoat Posted October 6, 2010 #19 Posted October 6, 2010 well with help im going to try and get it into this storage place. pull the battery put more seafoam in the old girl.. maybe pull plastics off do some crack repair. sand prime paint. and i got a nice looking 1986 in sight..
SilvrT Posted October 6, 2010 #20 Posted October 6, 2010 Panjandrum said: I plan on riding through the winter, like I did last year... unless this winter is like the one before last when snow stuck around for two months. (Yes, I am in Canada, but in the warm part!) I'm in the same area ... IMHO, it ain't all that warm and I sure don't like ridin in the rain...which we get a lot of around here as you know. Since weekends are the only time Nina & I can get out to ride, it don't happen all that often between now and next spring. My insurance has lapsed as of Oct 1st and I don't plan on re-insuring it again until mid april ... so, if/when we do get an opportunity to ride, it will be a day permit. Now, as for what I'll be doing to the scoot over the winter... Aside from doing the regular maintenance things... Installing levelling links Putting the stock size (150) tire back on the front Putting stock mufflers back on (coz I forgot what it sounds like with them) Installing a Clearview windshield Adding more LED lighting Replacing my sirius radio antenna ... it died I think Power polishing the paint (I accidentally got a bit of clear overspray on the upper parts when I was repainting the roof of the truck a year ago) ... no biggie and unnoticeable...but I can feel it yanno... probably nobody else would. Adding a few more "safety chrome" items (yet to be determined) Possibly getting some pinstriping work done. ...and this list may grow as time passes LOL
Guest Posted October 6, 2010 #21 Posted October 6, 2010 SilvrT said: Power polishing the paint (I accidentally got a bit of clear overspray on the upper parts when I was repainting the roof of the truck a year ago) ... no biggie and unnoticeable...but I can feel it yanno... probably nobody else would. Try going over the surfaces with a Mothers Clay Bar. I had enamel overspray on my RSV and car hood and it took it all off.
royalstarjac Posted October 6, 2010 #22 Posted October 6, 2010 I'm gonna ride! Just got my new Gerbings liner yesterday.
Cruser Posted October 6, 2010 #23 Posted October 6, 2010 After Christmas ,I will be pulling the plastic off and doing some repairs to it and some paint, While the plastic is off there are a few gaskets that I want to replace, a deep cleaning and some polish in places , the bike will be forsale in the spring. I have been picturing myself on a 2000 millenium edition and that's what I'm going to be riding next summer.
Zane Posted October 6, 2010 #24 Posted October 6, 2010 Panjandrum said: I plan on riding through the winter, like I did last year... unless this winter is like the one before last when snow stuck around for two months. Fingers crossed that the snow behaves, and stays on the mountains! (Yes, I am in Canada, but in the warm part!) Isn't that really Washington "North"? eh? heh, heh! Year round here in Cuba Norte!
Venturous Randy Posted October 6, 2010 #25 Posted October 6, 2010 Now that my divorce is over and my EX has moved two states away and I am keeping the house and garage, I can think about doing something. Sooooo, my hopes are to pull the engine apart and replace the 86 good transmission that's in it with one out of a 2nd gen Venture, which I already have, get a V-Max rearend which I have promised as soon as I send some money and check all the valve clearances. I also may want to replace my left side bag and repaint a few things, and do some polishing. I have a good wood stove in the garage and should have plenty of good oak ready to burn, plus a small refrigerator to keep things cool. My intent is to make the bike a little more interstate ready for some longer trips next year and to be able to enjoy life. Life is good. RandyA
