midnite Posted September 21, 2010 #1 Posted September 21, 2010 I have a vibration when going around 30-35 mph feels like the drive shaft has a shutter or the u-joint. What do you guys think? Any suggestions?
MikeWa Posted September 21, 2010 #2 Posted September 21, 2010 (edited) If it is your 2009 RSV take to the dealer and have them check it. It is still under warranty if it is the Silverado check the u-joints. Edited September 21, 2010 by MikeWa spelling
Sleeperhawk Posted September 21, 2010 #3 Posted September 21, 2010 Stupid question, but what gear are you riding in when doing 30 to 35
Venturous Randy Posted September 21, 2010 #4 Posted September 21, 2010 Sleeperhawk said: Stupid question, but what gear are you riding in when doing 30 to 35 Actually, that's a very good question and I wondered the same thing. RandyA
Bwhite Posted September 21, 2010 #5 Posted September 21, 2010 Usually 2nd...it seems like higher RPM's but that's the nature of the Yamaha. I had a hard time with my 1100 Vstar to remember, it's not a Hardley.
Monty Posted September 21, 2010 #6 Posted September 21, 2010 Isn't this like the third time you've had some type of vibration? You need to get that bike checked out good.
sarges46 Posted September 21, 2010 #7 Posted September 21, 2010 What about a carb sync and then maybe this tech article in the tech part for 2nd gens. Read through it and there is a part about tightening the nuts in a sequence to ensure proper alignment. http://venturerider.org/forum/showthread.php?t=1705
midnite Posted September 22, 2010 Author #8 Posted September 22, 2010 Okay, 2nd & 3rd gear will do it. carb sync was done awhile back. This just started a couple weeks ago about the same time my wife said she heard a sound like something was loose when hit a bump. Checked all bolts,nuts, etc everything was tight, rear shock still holding 38#.I do need to take by dealer to have bike checked over, I reckon, just hate to waste my money if they don't find the problem
