GaryZ Posted September 20, 2010 #1 Posted September 20, 2010 When I wind her up through the gears I am getting an oil warning light. Several others have said this is normal for the VR. What say you? Squid? Dingy? Others?
Grisolm1 Posted September 20, 2010 #2 Posted September 20, 2010 Never seen this and I regularly run to 7500 through the lower gears.
Dano Posted September 20, 2010 #3 Posted September 20, 2010 When under extreme duress by liberal use of the right-wrist-twist technique, the oil rushes to the back of the sump, exposing the contacts for the oil switch and sending a ground to the CMU input and triggering the light. If it does it randomly, then the wire is chaffed somewhere and touching a grounding point.
buddy Posted September 20, 2010 #4 Posted September 20, 2010 thats normal for these beast when I had my 83 it would do the same thing when I was running mine hard. all its for is a low warning light for the oil and when your ridding it hard the oil will move around some causing the light to come on. As long as you have plenty of oil in the case at least have the sight glass don't even worry about it just check your level once in a while and let the beast run wild or ride it like you stole it......
friesman Posted September 20, 2010 #5 Posted September 20, 2010 My 85 does that too under hard acceleration. I always have the oil halfway in the glass and I dont burn any so its ok. It still kinda unnerves me when it happens, but I am getting used to it. I really noticed under hard accelleration in a steep incline, when i was at Kruisn the Koots rally the mountain passes were fun with a good bit of accelleration. Brian
Snaggletooth Posted September 20, 2010 #6 Posted September 20, 2010 Once in a while when I stick all the oil against the rear of the engine case.....it will blink on for a few seconds. I hate seeing the icon....but I love the WOT!!
dingy Posted September 20, 2010 #7 Posted September 20, 2010 When I wind her up through the gears I am getting an oil warning light. Does the same thing on mine. At first it was a concern. But I have gotten used to it. Gary
Trader Posted September 20, 2010 #8 Posted September 20, 2010 ....but I love the WOT!! what is WOT?????????? -wearing of tires? -wristing of throttle?
Rocket Posted September 20, 2010 #9 Posted September 20, 2010 what is WOT?????????? -wearing of tires? -wristing of throttle? Wide Open Throttle (WOT), or in other words, Full throttle..... :thumbsup2:
Trader Posted September 20, 2010 #10 Posted September 20, 2010 DUH!!!!! never thought of that one! Thanks
GaryZ Posted September 20, 2010 Author #11 Posted September 20, 2010 thats normal for these beast when I had my 83 it would do the same thing when I was running mine hard. all its for is a low warning light for the oil and when your ridding it hard the oil will move around some causing the light to come on. As long as you have plenty of oil in the case at least have the sight glass don't even worry about it just check your level once in a while and let the beast run wild or ride it like you stole it...... This was what I guessed was happening. Thanks everyone for the quick responses!
jasonm. Posted September 22, 2010 #12 Posted September 22, 2010 Mine has never done it. Likely because I keep my oil level towards the high mark. It may come on when accelerating up the steep hills by me. But I don't look at the instruments when riding. After 21 years with this beast I know when to shift. I just ride.
GaryZ Posted September 22, 2010 Author #13 Posted September 22, 2010 My oil level was down at the "low" mark. I added to the upper mark and the light isn't coming on. Just like someone said, this warning light is an actual low oil warning instead of a low pressure warning. Good to know!
