If I do have to get my wisdom teeth out, I will take a taxi home! This clip is of a brother and sister who both had their wisdom teeth taken out and are headed home! :rotf::rotf::rotf::rotf:
Warning! It is a little lengthy and you might have a chuckle or two!:happy65:
[ame=http://www.youtube.com/watch?v=Ig-pZ4OyidY]YouTube - Brother and Sister Dental Odyssey[/ame]
  Quote
OMG, way too many one-liners, TV good not have dreamed up a scenario any better than this.
:rotf::rotf::rotf::rotf::rotf::rotf:
  Yammer Dan said:
One old folks tale claims your life is 1/2 over when you cut your wisdom teeth. I never got mine???:confused24:
Ya, I got lucky too and never got any either. The daughter wasn't as lucky and had to get six teeth taken out. She never got that goofy. The insurance would only pay for the four wisdom teeth and wouldn't cover the two that had to come out so they could get at them. Go figure.
When my wisdom teeth came in there was no room so they came part way in then started pushing all my other teeth forward. I went in to get them removed, one each week, when I moved to Saltspring. The first two were no problem. When I went in for the third one the dentist had a new assistant. The tooth would not come out. He worked on it for an hour. At one point he had his assistant behind me with her arm around my head holding it in place while he had his knee up on the arm of the chair pulling away. He finally gave up and said he was going to send me to the hospital when it finally worked loose and came out. The roots were shaped like an anchor and had hooked around the bone on each side. The next week I went back and he looked at the last tooth and poked a bit then handed the tool to his assistant and said "Here, you take this one out". She nearly fainted and I was somewhat agitated. He tapped the tooth and there was so much pressure behind it that it shot out of my mouth, bounced off the light and ricocheted over and hit the wall.
