05 RSTD cruise control will not stay on. Just started on the last ride it will stay on for about 3 miles then shuts down, I reset the switch and it will do the same not sure were to start.
Thanks for the info i am going to take them off, i just put them a couple weeks ago.
Thanks flb_78 you were right the money it was the brake lever setting off the cruise control. Went out today found the problem. This is one great site we have here,
Thanks Again
  • 6 months later...
I just bought a 2005 RSTD and it did that when I test drove it. There are no tassles on it. The problem cured itself after a couple of tanks of clean fuel and some Sea Foam. The bike had been sitting (only 6200 miles on it) and I suppose the dirty carbs were causing a misfire. I think the computer was shutting it down due to a loss of RPM or something. :322:
