I am trying to put the head light visor on and I am scared to pull or pry on the chrome piece around the light too much....Do I need to apply more force or is there a 'combination' to getting into the head light????
The chrome ring is held in place only by tabs bent over the back of the light housing. Carefully bend them out enough to pop the ring off. It will be a bit hard to get put properly back in place with the visor under it, but it will work. Be very careful to make sure the ring is seated all the way back on and the tabs are properly bent back in place, or you might have to split the fairing again in a week or two to fix it! I had mine come loose on one side within a couple of days because of that! But after redoing it correctly, it has been fine for over 80,000 miles. :080402gudl_prv:
Goose
