Anyone have any idea how long Ride On last in a tire? If the tire is not removed should it be okay or is this designed to be replaced before the tire wears out?
Just replaced all 4 tires on the VentureRanger. I run Ride on in all my tires on every vehicle/scooter, and when the removed the tires, the RideOn was as clean and as fresh as the day I put it in about 3 years ago.
  Zfrebird4 said:
What is: RIDE ON?
Thanks all
Jack Tharp
Ft Collins, CO
:fatsmiley:
It is a tire sealant you put inside your tires to keep them from going flat if you run over a nail or anything else small. You order it on-line.
