tufftom4 Posted September 9, 2010 #1 Posted September 9, 2010 I have a Reese Backpacker trailer and the original prop for the top was missing when I bought it I am trying to find some sort of prop for the top. I can only put it on the front so it has to be sturdy I thought about the gas filled ones like on my truck top but it is not strong enough for just one, anyone have an idea I have called all the trailer stores around me and no one has anything. I will make a prop out of wood but I would rather have something built in. Tom
Sideoftheroad Posted September 9, 2010 #2 Posted September 9, 2010 I have a Reese Backpacker trailer and the original prop for the top was missing when I bought it I am trying to find some sort of prop for the top. I can only put it on the front so it has to be sturdy I thought about the gas filled ones like on my truck top but it is not strong enough for just one, anyone have an idea I have called all the trailer stores around me and no one has anything. I will make a prop out of wood but I would rather have something built in. Tom Wonder if ones for the back of cars would be more sturdy. I would check junk yards too. e-bay item 320583929232 says its' good for 60 lbs lift. e-bay item 350387730767 (if I am reading it right) says up to 250 lbs. They have a chart for less or more as well. I actually just bought 2 lights for the back of my scoot from them. Fast delivery. I only need the one for under the trunk for the price (2 for $30 w/ free shipping), I went ahead bought it. Only difference that I can tell between theirs and custom dynamics is the entire row lights up as a running light vs. the 3 lights from C.D. Just went back and looked. They have one like C.D. e-bay 350388393866. I don't know if you can also do turn w/ the one from C.D. but this one you can. It is a bit cheaper especially after shipping cost.
LilBeaver Posted September 9, 2010 #3 Posted September 9, 2010 Your local autoparts store ought to have a hefty supply of the gas-shocks on hand. You can choose the appropriate weight rating for your trailer need. Another thought would be simply attaching a 'prop rod' like setup - mount it to the inside of the lid with a bracket of some sort for it to rest in the 'stowed' position. Then when you want to use it, open the lid and pivot the thing down; bada-bing.
dr_bar Posted September 9, 2010 #4 Posted September 9, 2010 Or you could toss the prop idea and fasten a small chain or cable that will only let the lid open just past the verticle...
Sideoftheroad Posted September 10, 2010 #5 Posted September 10, 2010 This might be the same idea that LilBeav is describing but with mine it basically has 2 pieces of flat metal and in the middle if a rivit holding the 2 pieces together. When you open it, the metal pieces are straight holding the lid open. It is the same idea when you open and close a ladder.
