funrider Posted October 31, 2007 #1 Posted October 31, 2007 I am new to the v4. bought a 1987 VR a short time back. It makes like a squeak. When I bought it the dealer said is was the venture wine. I have riden it just about 3500 miles and no problem, the noise hasn't changed. This chirp is like three rapid chirps, a slight pause and starts back over. You don't notice it after the rpm come up some or while you are riding, but at a idle, it is rather loud. Is this the chirp that is talked about or is there something else I need to be worried about?
Orrin Posted October 31, 2007 #2 Posted October 31, 2007 John, welcome to the club!!!!!! I am sure others will be along, more qualified than I am to diagnose your chirp. These bike are famous for noises. If you don't get much response repost on Watering Hole.
muffinman Posted October 31, 2007 #3 Posted October 31, 2007 No that is not the complained about chirp but I would not worry about it. Does it do it when the clutch is pulled in? All of these bikes have different quirks and if all is working right I would not even give it a thought. Jeff
SilvrT Posted October 31, 2007 #4 Posted October 31, 2007 I am new to the v4. bought a 1987 VR a short time back. It makes like a squeak. When I bought it the dealer said is was the venture wine. I have riden it just about 3500 miles and no problem, the noise hasn't changed. This chirp is like three rapid chirps, a slight pause and starts back over. You don't notice it after the rpm come up some or while you are riding, but at a idle, it is rather loud. Is this the chirp that is talked about or is there something else I need to be worried about? On my '85 I had similar noise...seemed to be coming from the water pump yet I replaced the pump and no change. On my '87 I get a noise at idle when the clutch is pulled in but as soon as I let the clutch out, the noise disappears. Funny thing about that tho, it doesn't always do it. Frankly, I learned to live with the noises these 2 scoots make coz nothing seems to fail on them. Guess it's kinda like the old Triumphs and BSA's... they rattled like crazy as if the engine was going to blow apart yet nothing happened...that's the way they were....ya gotta live with it (in most cases).
