SilvrT Posted August 29, 2010 Share #1 Posted August 29, 2010 So I got this trailer now to pull behind the scoot. It has those little 8" wheels ... can anyone tell me how much air I should maintain in them?? (I'm talkin air PRESSURE ... not volume LOL) Link to comment Share on other sites More sharing options...
muffinman Posted August 29, 2010 Share #2 Posted August 29, 2010 I run 15 psi in mine and its stable all the way up to 125 mph when loaded correctly Jeff Link to comment Share on other sites More sharing options...
Sgtglenn Posted August 29, 2010 Share #3 Posted August 29, 2010 I'm running 25 psi in my 5.30 x 12" trailer tires. Link to comment Share on other sites More sharing options...
SilvrT Posted August 29, 2010 Author Share #4 Posted August 29, 2010 I run 15 psi in mine and its stable all the way up to 125 mph when loaded correctly Jeff heh.... and I'm wondering now what it's like at 125 mph when NOT loaded correctly?? :eek: Link to comment Share on other sites More sharing options...
muffinman Posted August 29, 2010 Share #5 Posted August 29, 2010 I keep at least 35 lbs tounge weight at all times otherwise it qets real squirrely and can make the bike shimmy at higher speeds. Link to comment Share on other sites More sharing options...
straycatt Posted August 29, 2010 Share #6 Posted August 29, 2010 I don't have a lot of experience with my trailer, but.....I started out with 25 psi, but all of the tire was not on the ground. Now I go with what ever pressure will just keep the entire width of the tire in contact with the road for a given load. Usually around 20 pounds per inch squared. Link to comment Share on other sites More sharing options...
Brake Pad Posted August 29, 2010 Share #7 Posted August 29, 2010 just because, I too have the 12 " tires, Max air is 60 psi, But I to, run them at 53-55 at all times. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 29, 2010 Share #8 Posted August 29, 2010 The little 8 inch tires, on a trailer pulled behind a bike, with approx 100 to 300 pounds or so of weight combined, should have about 15-25 PSI in the tires. The MAX PSI rating you will find on the side of the tires is for when you are loading the tires with up to 800 to 1000 pounds of cargo weight PER TIRE, such as when they are used on a trailer that hauls a small boat or a couple of watercraft, with all the gear and gas etc. That doesn't apply to tires used in this situation. Service and then check the bearings often. Link to comment Share on other sites More sharing options...
dray Posted August 29, 2010 Share #9 Posted August 29, 2010 I run less than others have stated but works for me:thumbsup2: Link to comment Share on other sites More sharing options...
Rick Haywood Posted August 30, 2010 Share #10 Posted August 30, 2010 I run 23 pounds in my 12 inch tires, it says max psi is 50 poundsd but rides and pulls better with the 23 pounds Link to comment Share on other sites More sharing options...
kj5ix Posted August 30, 2010 Share #11 Posted August 30, 2010 I don't have a lot of experience with my trailer, but.....I started out with 25 psi, but all of the tire was not on the ground. Now I go with what ever pressure will just keep the entire width of the tire in contact with the road for a given load. Usually around 20 pounds per inch squared. That is what I do also. I spray water on the drive and pull it through and look at the tread pattern, and adjust to full tread, works great ,and also do that on the Roll-A-Home camper that is 300 dry close to 500 loaded. No problem so far and good tire wear. Just checked, and set the tires to in fact. Right side is 18, and left is 20,, and full tread on the ground. The Max pressure in the side wall of the tire is for Max Weight of the tire, not the trailer on these little light weight MC trailers. Mentioned above. Link to comment Share on other sites More sharing options...
