After re-organizing the garage...........I realize I used 75w90 Valvoline synthetic - Limited slip gear oil. Almost 3000 on the stuff and no problems what so ever. Should I change or just let it ride?
Edited by catman_4_ever
It'll be fine. I usually change mine every oil change or every other depending on how much time I have or how hot it is outside.
Hey Dave,
That Final Drive Lube will function properly in you bike. If you service the Complete Final Drive (grease drive shaft splines, change Final Drive Oil, etc.) every time you change out your rear tire you will be doing as well as most, and better than others.
Earl
