  Trader said:
OK....so if I remove the bolt (# 21 in parts list) from the bottom of the thermostat housing the whole housing , pipes and all, should be able to shift forward.
Once that bolt is removed...it looks like it is just the o-ring's holding it in place into the water pump housing....CORRECT?????
So then it should be just fanangaling to get the whole assembly out.
Both headers have been removed
There are two of the #21 bolts holding the metal housing in place.
You may also need to remove the right front crash bar to get the 90^ pipe out of the water pump housing.
Gary
Found a picture of the thermostat mounted to block.
Also, you mentioned you had trouble with the cross brace. On right side of picture, there is a bracket shown that can be unbolted from frame to remove cross brace tube.
Gary
Edited by dingy
cross brace note added
