CrazyHorse Posted August 17, 2010 #1 Posted August 17, 2010 (edited) Its my understanding that the 1st gen is rather limited in electrical capacity. Is there a way to improve this? I guess a new stator with slighty more power but dont you run into destroying your wiring. Is there another way to get upgraded power to other items heated seats grips etc. Like a transformer or something with its own wiring system? I dont know much about electricity so I'm sending out the challange to those out of the box thinkers that do. Edited August 17, 2010 by CrazyHorse
Monty Posted August 17, 2010 #2 Posted August 17, 2010 I guess you COULD rig up a GM alternator to run off the back wheel. Someone will be along to help you shortly.
flb_78 Posted August 17, 2010 #3 Posted August 17, 2010 nope. only way is to upgrade the charging system. no way to get 6 gallons of water out of a 5 gallon bucket.
mini-muffin Posted August 17, 2010 #4 Posted August 17, 2010 All you have to do is upgrade to the high output stator and that's it. Not really sure what you mean by the wires not handling it. Margaret
massey130 Posted August 17, 2010 #5 Posted August 17, 2010 All you have to do is upgrade to the high output stator and that's it. Not really sure what you mean by the wires not handling it. Margaret ~~~~~~~~~~~~ there are times when wire size is matched to system output. If the output is increased, the wires get hot and you have problems. all Jimbob needs to do is get the upgrade hi output stator and he should be good to go. ```````````````````````````` Jimbob, post this question in the first gen tech section so the first genners can give you more information.
dingy Posted August 17, 2010 #6 Posted August 17, 2010 Transformers only work with AC, not DC. Upgrading the stator as previously suggested, along with an upgraded voltage regulator. You need to do the regulator, so the extra power from the stator doesn't get dumped to ground. And a new Absorbed Glass Mat battery. Gary
