hdroyer Posted August 10, 2010 #1 Posted August 10, 2010 My tach is gone crazy runs like it's missing, removed TCI cleaned connections moving to top of air box. If I swap plug wire and connections to the left side coils will this let me know if the #2 coil is bad. Any one coming to Asheville have a good 83 TCI I could use to test. How do you get the cover off the TCI to get to the diodes to look for bad ones.
Rocket Posted August 10, 2010 #2 Posted August 10, 2010 Remove the screws to look, but to do more, like repairs.... http://www.venturerider.org/forum/showthread.php?threadid=51767 BTW this thread is just down the list, on the same page of active threads.
mrich12000 Posted August 10, 2010 #3 Posted August 10, 2010 Hi Paul.. Look at this post.. http://www.venturerider.org/forum/showthread.php?t=51767
hdroyer Posted August 10, 2010 Author #4 Posted August 10, 2010 I did read the thread should have posted on it. I switched the plug wires and the connections to the left side coils no change I guess the coil is good. Looking like the TCI?
