Yammy Posted August 9, 2010 #1 Posted August 9, 2010 Used my carbtune for the first time. 1 & 2 carbs were slightly off. 3 & 4 were even, but there was about 3 difference between the left and right side. Got them adjusted so there all within 1. I noticed there was a lot of bounce on the needles of 1 & 2. 3 & 4 were very steady. Is there something I can do reduce the bounce? Anyone else have this problem? I never thought of changing sides to see if it was the carbs or the guage, until just now. In the carbtune manual it said some adjust the carbs at a high idle. Wondering what most do when syncing?
Mike G in SC Posted August 10, 2010 #2 Posted August 10, 2010 First time I used mine,,,, I didn't read the manual. I neglected to include the reducer thingies. (The part where you cut off a few inches of hose and insert the reducers to reduce the jump.) It was hell trying to watch the action. If you already did that,,,,,,nevermind. Mike G in SC
steamer Posted August 10, 2010 #3 Posted August 10, 2010 Just did mine for first time,a lot of bounce if the idle is low.I increased the idle until the bounce settled out.It didn't take much,worked great after that.
bikenut Posted August 10, 2010 #4 Posted August 10, 2010 Like what Mike said above . You have to have the plastic reducers put in line for each meter and then all bounce will go away. This reducer tube came with the unit.I can not remember if it was one piece and you have to cut it into four pieces or not can not remember. That's what happens when you get this old.LOL Just cut the main line like Mike stated and insert inline . Hope this helps
steamer Posted August 10, 2010 #5 Posted August 10, 2010 Set up your carbtune just like the instructions say to.If it's not set up properly it will bounce so bad you won't be able to get an accuate reading.
Yammy Posted August 10, 2010 Author #6 Posted August 10, 2010 Just did mine for first time,a lot of bounce if the idle is low.I increased the idle until the bounce settled out.It didn't take much,worked great after that. Did you turn up the idle or use the throttle? If you did turn up the idle where is the adjustment? Looks like i might need to get a tach if you did the first. I think the unit is set up right. I cut 4 inches off each of the tubes. Cut the clear reducer tube into 4 equal lengths and put them in. I put the 4 inch reduced side of the hose to the bike and the other to the carbtune. Only two on the left side (1 & 2) were erratic. Thanks
gibvel Posted August 10, 2010 #7 Posted August 10, 2010 Did you turn up the idle or use the throttle? If you did turn up the idle where is the adjustment? Looks like i might need to get a tach if you did the first. I think the unit is set up right. I cut 4 inches off each of the tubes. Cut the clear reducer tube into 4 equal lengths and put them in. I put the 4 inch reduced side of the hose to the bike and the other to the carbtune. Only two on the left side (1 & 2) were erratic. Thanks I'm sure he adjusted the idle. The idle screw is on the right side (as you sit on the bike) just above and slightly forward of the right rear cylinder. It's a black thumb screw with a philips head in the middle. It should be fairly close to the bottom of the tank.
Yammy Posted August 10, 2010 Author #8 Posted August 10, 2010 I'm sure he adjusted the idle. The idle screw is on the right side (as you sit on the bike) just above and slightly forward of the right rear cylinder. It's a black thumb screw with a philips head in the middle. It should be fairly close to the bottom of the tank. Thanks Mark. Looks like I need to get a tach. Is it the man with the most tools before he dies wins?
Shipper Posted August 10, 2010 #9 Posted August 10, 2010 Is it the man with the most tools before he dies wins? Tools imply WORK. He who has the most TOYS when he dies, wins!
RandyR Posted August 10, 2010 #10 Posted August 10, 2010 You really shouldn't need a tach. Just increase the idle ever so slightly while doing the carbtune, then set it back down when done.
gibvel Posted August 11, 2010 #11 Posted August 11, 2010 You really shouldn't need a tach. Just increase the idle ever so slightly while doing the carbtune, then set it back down when done. Use the philips "Star" to tell how much you turn it up then reduce it back to the same place it was before you adjusted it. Unless you really WANT to get a new tool!
Yammy Posted August 11, 2010 Author #12 Posted August 11, 2010 This forum is great. Bunch of people with a love for biking and a knowledge base that's knows no bounds. Thanks all. Mark
Squidley Posted August 11, 2010 #13 Posted August 11, 2010 This forum is great. Bunch of people with a love for biking and a knowledge base that's knows no bounds. Thanks all. Mark ....and we'll help you spend you money Too!
Yammy Posted August 11, 2010 Author #14 Posted August 11, 2010 If you asked my Wife she would say I don't need help. I'm very good at it.
