hdroyer Posted August 8, 2010 #1 Posted August 8, 2010 At the Asheville East KOA road today half way back to KOA tach drops to 0. Roll of throttle tach shows RPM's again, roll on throttle about 2000 drops to 0. Coasting down hill shows RPM's 3000 roll on throttle hard RPM's come back. Cleaned the connection on left side any thoughts what could be hope not the TCI, starts fine idles good. Your help as always appreciated.
sarges46 Posted August 8, 2010 #2 Posted August 8, 2010 Couple of things ...maybe...the real 1st genners will correct this.....maybe the tci is heating up...some have moved it to on top of the airbox. Or.....sorry to say...it may be the beginning of the end for it. Hopefully there are other ideas out there.
Rocket Posted August 9, 2010 #3 Posted August 9, 2010 Couple of things ...maybe...the real 1st genners will correct this.....maybe the tci is heating up...some have moved it to on top of the airbox. Or.....sorry to say...it may be the beginning of the end for it. Hopefully there are other ideas out there. Another possibility is #2 coil, as the tach gets its signal from it. It is acting up or the primary connections for it are loose / dirty. I have had similar, with a loose connection before.
hdroyer Posted August 9, 2010 Author #4 Posted August 9, 2010 At the Asheville East KOA road today half way back to KOA tach drops to 0. Roll of throttle tach shows RPM's again, roll on throttle about 2000 drops to 0. Coasting down hill shows RPM's 3000 roll on throttle hard RPM's come back. Cleaned the connection on left side any thoughts what could be hope not the TCI, starts fine idles good. Your help as always appreciated. New symptom the information display showed the kickstand, brake fluid and oil low after I reinstalled the battery after checking for water on TCI, the display was re soldered.
