fordpol Posted August 7, 2010 #1 Posted August 7, 2010 Any help appreciated the radio on my 08 RSV locks up randomly - can't change stations or enen shut it off for that matter. Only thing that will do anything is the volume dial. Until I pull into the dealers lot and park then works normal! Frustrating! Ken!
MikeWa Posted August 8, 2010 #2 Posted August 8, 2010 There have been a number of posts on this issue. Here is one I posted a couple of months ago. http://www.venturerider.org/forum/showthread.php?t=50550 Mike
bongobobny Posted August 8, 2010 #3 Posted August 8, 2010 You may want to try unseating the multipin connector in the fairing, spray clean, and add dielectric grease to the connectors to see if that clears up the issue. This is actually a fairly common issue with 2nd gens...
rickardracing Posted August 8, 2010 #4 Posted August 8, 2010 You may want to try unseating the multipin connector in the fairing, spray clean, and add dielectric grease to the connectors to see if that clears up the issue. This is actually a fairly common issue with 2nd gens... I agree, I had problems with my cb. The squealch quit working. I was picking up stuff miles away. I took all the round connectors apart, sprayed electrical connector cleaner into the plugs, put then together and took them apart a few times, then sprayed more cleaner in them, hit them with compressed air, then added a dab of dielectric grease. Took care of the issue. I would bet money this will take care of it.
uechi kid Posted August 8, 2010 #5 Posted August 8, 2010 Had the same thing happen. The above posts are right on the money. I'd take it to the dealer and make him do it. It's under warrenty.
Proud Dad Posted August 8, 2010 #6 Posted August 8, 2010 Dealer tried spraying the contacts, didn't help. Was locking up randomly. Replaced under warranty. Seem it is common issue. Had no problems with new unit.
fordpol Posted August 8, 2010 Author #7 Posted August 8, 2010 Thanks everyone! Biggest frustration is it works everytime I pull into the dealers lot! I will clean up the connectors! Ken!
