I traded some BUBS for a set of Tour Deluxe factory mufflers. The TD dpipes arrive today and the opening to the pipes is 1/4 inch bigger than the BUBS, in fact the the BUB muffler opening will slide into the TD muffler opening , aren't they supposed to be exactly the same? I tightened down most of the set screws but I am uncomfortable going much tighter. The exhaust is leaking at the end of the header. What I am i doing wrong?
Do you have the gaskets installed? The stock mufflers use gaskets where they slip on. Some of the aftermarket ones do not. I'm not sure about the Bubs.
